Ok, here goes.
Going to leave measurements here so I don't lose them [emoji4]
Total Inner diameter - 30mm
Depth from caseback rim to dial rim - 6mm
Stem tube tap - 1mm
The caseback is a puzzle.
The ones I have the caseback lip fits inside the case rim. This one is different.
Hi ro63rto,
Try a ronda 515 or a 517 if you want also a day. You will need a ring to keep it seated. Plastic works for the ring...I'm a little in a hurry right now but wanted to drop this line before I go. There is also ready made rings that can be customized to fit. Then you will need a fitting dial and hands...plenty of fun ahead!
Cheers,
Bob
Hi ro63rto,
Cheers,
Bob
Thanks. [emoji106] I'll take a look at those movements. Hope the date is BIG. My eyes ain't what they used to be [emoji1]
You need to now the high from the dial to the center of the stem . This is called the T . You could measure it if you measure from the point where the dial rest to the center of crown tube . Takes of the dial thickness . Then look if the movement has the same T at http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk.Lot of work i now but there is a help in the advanced to the right .
I think finding a case back would be tough.
You may end up having to get one made.
Anil
Really? If thats the case just as well it was only £2.
Might just invest the £££ in a sandwich dial for my homage Italian dive watch then.
A way to do it would be to buy a Rolex style crystal (without the date magnifier) that is a good fit over the lip on the back. That way you'll have a cheap display back. :)
