ETA Quartz tech sheets
huge thanks clockboy, i have one that seems to of sprung into life after a tad of quartz oil and a coil check and voltage check done, they do not tick like a normal quartz, this seems to tick every 20 SECS, so interested to see the specs etc. rogart63 has sent me a couple of replacements just in case i need them, so thanks to that fine gentleman for his help.
Hi It seems like the swatch group who own eta and several other brands have now closed the portal through which we mere mortals were able to access the tech sheets and are now only available to customers purchasing their products, probably in great numbers.
They have the most of the tech shhets still online, but some of them which have been obselete for quite a time is taken away.
https://shopb2b.eta.ch/?___store=en
Up in the left corner you just choose if you want the quartz or the mechanical tech sheets.
The 579.002 is one of those movements that is no longer supported and it was replaced with the ETA 902.002.
https://shopb2b.eta.ch/902-002.html#technical-documents
