Serendipity... I was just watching you on You tube grave off a balance staff rivet of an Elgin balance, then I came here and your doing more balance staff work! :D
You describe the process really well with the aide of the drawing beforehand. Nicely done JD!
I'll watch it in full later, rather than the snippets I have already...
1 hour ago, jdrichard said:
This was a very tricky fix, after making a balance staff.
Sent from my GT-N5110 using Tapatalk
Another Great Vid JD. I have just done his job (hour ago). What a fiddly job. I have no idea (as yet) if the impulse jewel fitted is too long or the correct size.
Great video. Here we see a watchmaker work not a watch repairer. I could watch your videos all day. :Bravo:
The jewel was a bit long but managed to reduce its height with a very fine diamond lap.
Sometimes my measurements when cutting the staff are bang on and all there is, is a bit of pivot shortening. This one was very tricky.
From you, this is a great compliment. I am learning every day and have gone far since I purchased and started using a watch lathe. Again, thank you Sir.
Serendipity... I was just watching you on You tube grave off a balance staff rivet of an Elgin balance, then I came here and your doing more balance staff work! [emoji3]
Thank you very much. The first staff I made for this watch, I accidentally cut the pivot too short on the upper balance: I rushed. I had to make and fit another one from scratch. Thanks for the nice words. I’m now competing with NetFlix: JDFlix
