Wenger Swiss Military Stem removal help
As far as i know there were only two rebberg designs, i have an image somewhere. -
We need to identify the movement to help you, but the oldest of these Rolco watches use Aegler-Rebberg movements that lack a calibre number and are very difficult to identify. You may end up having to make or modify a stem to fit . Post pictures of both sides of the movement when you have it and the size of the movement and hopefully it’s one that has a calibre number. Gruen used a lot of the same Aegler movements at the time and it’s worth comparing your movement with those if you can’t find it labeled as an Aegler or Rolex/Rolco calibre. Best Regards, Mark
Onlly a pro's eye would notice that OH, you've still got it old fella 🙂 -
The triple lobed spring, as you suggest needs to be rotated to remove it or replace it. Suitably shaped pegwood should suffice, but tools (shaped as you describe) for the purpose also exist. If you have an assorted of replacement springs, a trilobe style KIF spring of the right size might fit. The other spring securing the jewel also needs rotating. There is a slight opening in the setting at about the 5 o’clock position in your photo and one side of the spring should be able to be removed there when rotated into position. Hope that helps, Mark
