Newcomer Watch enthusiast with big plans
JBT
Hello everyone, I currently work as an air traffic controller in Miami but my passion is the art of watchmaking. I am on a quest to create my own line of high end watches. I am designing a trademark case and a unique design identity using Solidworks CAD. I love to design beautiful things that you can stare at and just indulge. I am here to inquire and digest the wealth of knowledge all of you experts possess. I have plenty of questions that I hope you guys can help me with, to build my dream, but at the same time, to build a friendship with everyone.
On aircraft, everything from flight deck avionics equipment, to engines and seats. On watches I’ve been practicing on my grandfathers old pocket watch he gave me. So far im building up the right tools to work on them but still learning what common practices are on the watch side of things. Luckily I’m used to researching procedures and illustrated parts catalogs with aircraft maintenance which helps to troubleshoot and identify what needs to be done for the repair. Im not a watchmaker yet by any means but I’m trying.
Welcome! I would like to do similar things myself! I suspect quite  a few of us would and some on here may be doing just that right now in secret! I hope your plans take off though! :D sorry couldn't resist that little pun. There are not enough high end watchmakers. I am just playing, discovering and enjoying at the moment. Probably doing too much of that.
I think it would be good if you could build the prototype yourself. I met someone by chance at a car show, he was starting a micro brand, not high end, and there was a lot he didn't quite get that I have already picked up from this forum and the YouTube videos Mark has done.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
