rotor compatibility 2824 to sw200?
Is the rotor of a 2824 movement compatible with an sw200? I see gold after market rotors on ebay and other sites for 2824 but my watch runs an sw200. Some says sw200 is a clone of 2824 and parts are interchangeable and some state no. Does anyone know definitively regarding the rotor? Thanx
I think you understand that there is no gold in these, but a plating of similar color?
41 minutes ago, Winstriumphs said:
I would like to find a real gold one.
Really. I could not weigh it precisely but a standard 2824 weight is approx. 2.5g with the bearing. And I don't know what alloy it is made of, but a density of 9 kg/dm3 shouldn't be far off. Gold is 19.25, so it would need about 4g, at today prices that is about 200 USD. Plus very optimistically the same would go the specialist which makes this as an one-off, there you have an 400 USD upgrade for your Invicta watch. In my opinion there are better way to spend that money.
My goal originally was to drop one of the gold color rotors for a 2824 into my sw200 Invicta. A modest upgrade. Then later I got the idea to build a Submariner 16610 with upgraded lume to blue Chromalite sapphire case back and real gold rotor. Submariner in red. A prototype with some of the finest submariner features fit together into one watch.
1 hour ago, CaptCalvin said:
Yeah not very realistic at all. I can guarantee you no solid gold 2824 rotors exist. Also you ain't gettin' any chromalight. Not without some connections in Rolex.
I can obtain bgw9 lume they sell it online. There is notilumnia blue as well both almost identical in quality to Chromalite. The rotor idea was gold plated 18 or 24k. My idea was to buy the 16610 parts mostly original though a few after market maybe could be swapped. I would find a used worn dial and have that refinished to new but with bgw9 lume job and Submariner in red. Gold plate the rotor, wherever they would do that, and add the sapphire caseback. Voila. I have to find affordable parts and a place to plate the rotor. Thoughest part might be luming the pip on the bezel with the blue lume. Dont know if a ceramic insert exists for the watch but aluminum would be fine if it was original. The goal is NOT a fake Rolex but an inspired prototype homage not for sale but personal use.
Edited by Winstriumphs
You are very unlikely to find just bare chronometer movements to buy unless they've been taken out of a watch, and there is a reason why these might be taken out to be sold. Why does the chronometer certification mean so much to you? It's nothing more than a marketing gimmick these days. If it's just for yourself wouldn't it be enough for you to know that your movement is just as accurate as a chronometer rated watch? COSC has what I consider to be rather relaxed requirements for granting the chronometer certification. Most ETA  movements can achieve the COSC standard for chronometers with a little bit of regulation.
Edited by CaptCalvin
Where can a watch be sent orther than COSC to obtain a -2 to 2 sec per day standard? Who will test and work on the watch to obtain that standard?
A watchmaker makes a movement or accurizes an existing movement, then it's sent to whichever organization to get tested. If it gets past all the tests they stamp their seal of approval on it and it officially becomes a chronometer. Only Rolex observes a -2/+2 standard(superlative chronometer) as far as I'm aware and don't expect them to put the "superlative chronometer" lable an any watch other than their own.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
