Best Way To Pick Up Jewels
DrRock
Morning, oh experts :)
I finally received my assortment of 100 jewels from eBay, all nicely done up in a pretty little baggie with a professional-looking business card. And there are several in there that are the right size for my fake Chopard watch balance wheel. You may recall that this watch, while fake, looks superb, and the jewel flew out of the little clasp at the end of the balance wheel stem when I was in there adjusting the little +/- lever. The watch had been gaining about 5 minutes every hour, and I found the adjuster was hard over to the + side. Moving it to the middle had the watch keeping pretty good time. But it only runs when in the face down position, due to the missing jewel - as soon as I turn the watch over, the balance wheel stem passes through the hole where the jewel was, and stops. Turn it back over, and hey presto, it works again.
So I bought these jewels off eBay for $6.95 and free postage - had to be worth a try. But now I have the problem of trying to pick one up, manipulate it to be the right way up, and placing it in the holder before clamping the little spring clamp over it. That's the clamp that had been unclamped, and when I took the watch back off, it flew open and the jewel flew out, never to be found.
So, my question: what is the best way to pick up a tiny, tiny jewel? My best forceps (sorry, tweezers to you non-surgeons :) ) have really good tips, but due to the shape of the jewels, it is very hard to pick one up without it rotating in the jaws of the forceps and flipping out. I've already lost 3 from my assortment of 100 - although by some miracle, I did find one of them on my desk, lying up against my little wooden fence that surrounds the working area.  Do you guys just pick up and manipulate jewels with forceps/tweezers, or do you use Rodico, or some other method for doing it?
What is the best way? Or do I need something like a flat-bladed tool (I was thinking maybe the end of a number 11 scalpel blade - that's the long pointy one), then use that to carry the jewel to the "socket" and then gently slide it off using forceps? All ideas and suggestions welcome.
Pete, Brisbane
Edited by DrRock
+1 mwilkes
For hole jewels I usually use tweezers and for preference I use Dumont 5a tweezers as I find the off-set gives me a little more manoeuvrability than the straight 5's or 4's. But for end stones and Incabloc springs I don't think that there is any thing to beat the jewel picker upper, at any price. I have not had a single flyer since getting mine last year.
It has also vastly improved the ease and speed with which balance pivots can be oiled.
I always used to start with the end stone upside down on the bench and the hole jewel next to it, also upside down. Place a drop of oil on the end stone, pick the hole jewel up and drop it onto the end stone, then turn the whole thing over, pick it up and install.
The number of times that the end stone has stuck to the tip of the oiler, or the hole jewel hasn't gone on straight, or the whole lot has launched into oblivion...
Now I install the hole jewel into the balance cock (or the main plate, which ever) dry, pick the end stone up with the picker upper by its top surface, apply oil to its lower surface safe in the knowledge that the surface tension of the oil cannot over come the grip, then position the end stone over the hole jewel and ease it off the picker upper with the tips of the 5a's. Complete doddle.
Thank you :)  I just KNEW I needed another tool - yeay! :)
They're like tiny spoons. I suspect the tip of my #11 scalpel blade may do the same thing, but it isn't scooped out, so the jewel can still fall off it.
Thanks for the suggestion - I'll see if my nearest watch tool man has anything like those (www.watchbitz.com.au)  He is only about 40 minutes drive away.
Just for you Geo...
This is the smallest one in the range, I don't think that I would have a use for the bigger ones.
And no, that jewel isn't balanced, it's hanging.
I don't know how long the sticky lasts. I've had mine just over a year now and have used it a lot with no loss of tackiness.
When it does eventually lose its stick I suspect that it will only require a rinse in cold water and then air dry to rejuvenate it, although at the price I will probably just replace it.
Excellent!  Thanks for the hint - I've just ordered a set from Cousins, as my local bloke doesn't have them. Seems a reasonable price, and postage is only a couple of pounds (about $Aus5) so now I'll just wait for them to arrive before losing any more jewels. I ordered all 3 sizes - I can use the others for picking up the tiny fishing hooks I use for my fly tying.
Great idea - thanks again :)
Pete, Brisbane
Edited by DrRock
I used to drive myself crazy picking them up with #5 tweezers. Now I use some Rodico on a piece of pegwood. Haven't lost one since. The picker uppers look cool and I assume it's easier getting the jewel off them than off the Rodico.
Easier and cleaner as the silicon tip leaves no residue.
Pete, Brisbane
Hey Pete,
Personally I don't use steel tweezers due to their springiness when dealing with such items; I only use brass Dumont Tweezers, and keep them well dressed.
My favorite pair are No.4 Dumonts I purchased secondhand off fleabay.  They have been ground back about one-third of their length, so they aren't quite as pointy, but are now nicely shaped for 99% of the tasks I do servicing watches.  The only time I have ever had trouble picking anything up with my No.4, including Incabloc Jewels, is when they needed re-dressing.
I have in the past done this & purchased jewels. The issues I have found are 1) sorting them into sizes & 2) I have only changed one jewel (pallet) and despite a packet full not one was the correct size so purchased from Cousins.The same as balance staffs I have packets of them plus loose ones but as yet I have never found the correct one when needed. I now just purchase the correct size one from Cousins or Balancestaffs.com.
    • Most all my 404 candidates are coming from swap meets and "antiques fairs". One more $4US plus battery and elbow grease. Unnamed digital on a decent ss bracelet. Gains 10 seconds a day so not that accurate...
    • I voted.for the 6.99 assuming £, which works out to $8.74US at the current exchange rate.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
