Why is it like this?
looking through my spares, in an attempt to find a barrel cover for another watch, I came across these.20200202_084902.thumb.jpg.a6193d45d58eaa64209bb2c0adf002e3.jpg  I didn't remove them from anything, I probably just received them in a box of miscellaneous watch parts from Ebay or the like.  Does anybody have an idea about what the extra details do and what they might be from, age, excreta?
Thanks.
Shane
The most common Maltese stopworks allow 4 turns, most springs develop 6 or 6.5 turns, so the weakest turns on both ends of wind are avoided.
The gear ratios between barrel and center wheel are also changed so that a useful power reserve is obtained on 4 turns.
Some maltese cross allow 5 turns, but more than that and the Maltese style geometry doesn't work reliably any more.
I found pictures illustrating what they looked like in several other posts.
I remember seeing some of the other components involved whilst previously sorting through boxes of miscellaneous parts.
It would be nice if I had enough parts to make a complete assembly.
Was it just a mechanism to reduce the likelihood of a broken mainspring until better manufacturing processes rendered it obsolete or did it have some other benefit?
Thanks for your time.
Shane
I suppose a better average spring rate, which would result in a more accurate watch throughout the day.   Sacrificing some duration in favor of  accuracy wouldn't be a bad thing and was probably considered a significant improvement.
Thanks again.
It was to use a more consistent power from the spring. In the pic (from Vintagewatchstraps - great site) you see a typical graph showing power from zero to full wind. The stopworks allow using just the "good" part.
They do also help protect against broken springs, though that's not their purpose. Since there will always be a wrap of spring in the barrel wall at full wind the stress on the hook (whatever form it may be) is greatly reduced. This is an issue in old clocks in particular; I see some 250+ year old Neuchateloise clocks fairly regularly and they are always missing the stopworks. These old boys have tremendously powerful springs, but run a full 8-9 days on just 3.5 turns of spring. They invariably have simple hole end mainsprings, and after hundreds of cycles getting that hole stressed (with the stopworks missing), one day, maybe, BOOM.
I always remake them when missing, even if the customer refuses, just out of respect for the clock. In the pic you can see it's a different type of stopworks, simpler than Maltese cross but very effective. The partial gear has a friction spring to maintain its position, where the Maltese uses the geometry of the cross to hold position.
  • 2 years later...
On 2/2/2020 at 9:28 AM, nickelsilver said:
the maltese cross would be mounted. It limits the number of turns you can wind up and also allows prearming the barrel.
On 2/2/2020 at 11:06 AM, watchweasol said:
he maltese cross (stop work),  a mainspring pre loading and protection device as you cant overwind
Good morning, Nickelsilver and Watchweasol.
I always find your posts to be informative and worth reading.
I will preface my following comments and questions with (the information I found didn't mention the incredibly strong mainsprings of some clocks and was just focused on vintage pocket watches).
The Maltese cross seems to be a mechanical means of averaging the mainspring's influence, with regards to amplitude, for more accurate time keeping.  As with most compromises, you must give up something in return... runtime.
As better metallurgy, manufacturing, design and understanding brought mainsprings with a more consistent power curves into both production use and replacement availability, many of these Maltese crosses where removed and discarded.  If, a NOS spring (of the original material and design) was found, it probably wouldn't be the best of ideas to use because of age harding and embrittlment of the steel.  I would be afraid of a significantly shortened service life before the inevitable and catastrophic failure.
I am on the fence between preserving the historical accuracy of an antique and improving an instruments ability to perform its intended function.  If the modifications started so long ago (when this was accepted practice) was it wrong?  Is the evolution of any individual time piece acceptable if better accuracy and higher stamina are the end results?
I myself would not modify one if I received it in original condition but I also would not carry it around running and if I received one that was modified well before my father was born, I probably wouldn't go out of my way to restore it.
What are your thoughts?
Thank you.
Shane
Hi  I think the simple answer is that if the clock/watch is fitted with the stop work then it should remain regardless of whether the mainspring is changed for a modern one. The watch/clock was designed that way and should remain so.
If you come across a watch/clock where the stop work has been removed one has to ask why. Did the repairman not understand the principal and therefore removed it ? was it broken and the repairman couldnt/wouldnt find the relative parts or his customer /client not want to pay the extra costs involved  in sourcing the parts. There are many IFs and BUTS, but in my opinion if thats how it was made thats how it should remain if only for Historical accuracy and authenticity.
I hope this answers your question, bear in mind this is only MY opinion others may differ.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ?
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
