Hello there, I have recently acquired a gucci 9300 watch. It's a chronograph and as far as I can see looks akin to other pictures of this watch on the internet. None of the hands are moving however I think that  this Is due to the fact that it hasn't been worn/serviced/touched for a few years. I have purchased a watch repair kit and am thinking of replacing the battery and maybe adjusting the links. Any advice on this, what battery to use, things to look out for ect.
Any help greatly appreciated thanks for your time,
Dylan.
Any first brand battery is fine. Being it a quartz watches there are chances that it will not work anyway due to the module being faulty. Work carefully to not lose or damage parts. There is many many videos you can watch on the internet.
9 hours ago, Dylan123 said:
Do you know what type of battery?
Begin by opening it (ideal for beginners is a lever-type snap case back opener). You may also need a small press to close it. Then identify the battery which is easy to obtain at electronic stores or even online. If the time and cost associated with the above is excessive then I recommend that you continue having a watch shop to do that for you.
Hi Dylan one can only second the advise given by jdm , the only way to find the battery type is to open the watch,  check the battery terminals for corrosion, A green crystaline deposit. If the watch has been stored with the battery in there is always the possibility of it leaking due to age.      All the best
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
