I recently acquired an Avia Alarm Quartz watch, from the '80s. Unfortunately, it has water damage, and although the watch itself has cleaned up nicely, the movement doesn't work.
The mechanicals look okay, but the circuit board is toast and I think the coil has gone too. It's a real shame, as the alarm function makes it a bit unusual I think.
The long shot referred to in the title is, does anyone have a movement or circuit board and coil, or seen one for sale anywhere?
There have been some on eBay in the past, but nothing at the moment.
You can use an ohm meter and test it in various ways to eventually pin point which part (or parts) is not working...
That's how I found out that the coil was bust on a watch with an ETA ESA quartz, once.
