CASIO EDIFICE
HI,I am not sure where i should post this question, if at all,but a friend of mine asked if i could clean up his Casio Edifice EF -101 and i duly obliged.it needed a new crystal.no problem.then it came to the bracelet.Casio no longer supply this model and the lugs are narrow (12mm) and the end pieces were some sort of plastic. i have hunted everywhere for replacements without any luck.any ideas how to fix this without too much expense? grateful for any suggestions (within reason:wub:)
As said above one possibility could be 3D printing but expect to pay at very least the cost of a new same watch. Maybe you can fix the end links with epoxy glue, sand excess material and paint.
i dont think its worth the bother.might try bits from other bracelets!
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
