Got an email from a chap I sold a watch on ebay last year. Initial thought,"Here we go, wants a refund"........ But no, reading on he says he opened the watch and was so impressed with the work I'd done he wants me to service some of his collection....... He lives local, so going to see him and have a look. Told him I'm not a professional and do not have indemnity insurance, but he says that's ok.
Shall let you know how I get on..............
What a wonderful compliment mate, and a great confidence builder, which is so important as well.
One piece of advise mate.  If the watches he wants you to work on are ones that you could not easily replace (due to cost or rarity), get a statutory declaration signed by him that covers your obligations responsibilities if the watch is damaged or lost in your custody.  You've already explained to him that you're not a professional, so he should have no issues with signing it.  If he does, then thank him for the offer, and walk away.
This is VERY important protection for you, and something I will be indeed doing with any watch I work on over $700 replacement cost.
Remember, in regards to this transaction, he is NOT your friend, he is a client ... and the two should never mix.
Edited by Lawson
As a matter of interest what is the cost of indemnity insurance in the UK. Just thinking I have worked on a lot of clocks that are worth a few hundred pounds & as yet never damaged one but there is always the first time!!!!
The rewards for patience, industry and merit are yours Legarm and well deserved I am sure.  Heed the advice of the ancients others though, a little click flying into oblivion can cosy a packet for a good watch.
Congratulations,
Vic
  • 2 months later...
Update
Just thought I'd let you guys, & Gals..... know what has happened with the servicing of the gents watches. Well it's gone very well, I explained this was my hobby and that I would do them in my own time and with no guarantees, he was absolutely fine with this and so far have done about 12 for him. They are better quality watches, that I can't afford, so he puts them up for resale and makes a tidy profit. So far I have, now been able to afford the Timegrapher 1900, I was yearning for and still have a few quid stashed away.
He is pleased and so am I.
Got another commission to do an Omega Genevé, cal 565 service and repair, for an acquaintance, all done and he was over the moon as it was his long departed fathers. Did it mainly for the experience, but he was very grateful....... I like working on quality watches, you can feel the difference as you service them.
I wish I was young enough to train to be a bona fide watchmaker, but the years are flying past and I don't think the missus would like it.
Any way I hope you are all well and I await my friends next batch of goodies.
Need to work out what's next on the shopping list................. :)
Good news, especially if it got you a T1900, I think that's the one Clockboy has got and seems well pleased with it. Also 12 watches gone for re-sale is a bit more than tinkering so outstanding work.
I was out getting suits for the daughters wedding and one of my putative son in laws relations was there and asked if I could have a look at a pocket watch for him, not sure of the make but later advised it is an Omega. Oh dear ! I had already said I would look at it for him when I thought it would just be run of the mill services or something like that. I await its arrival but with a little trepidation.
Cheers,
Vic
Edited by Vich
Good Luck Vic. Omegas are lovely to work on, as everything seems to fit smoothly, no encouraging things into holes etc.
Pics of it would be nice....
Keith
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
