favre-leuba harpoon II
Happy New Year all!  I have FL that has an issue with the keyless works. The stem doesn't lock in and as I couldn't identify a release (either lever or screw) I've partially stripped it down from the dial side.  I cannot glean any information in my searches at FL.com or in general for a schematic or teardown.  Would anyone here know about this brand?
Is this part broken ? Usually this is the one that holds the stem inside the movement. It also pivots along with the stem and gets the movement into normal/date changing/time setting mode.
What about the lever above it ? Could that be the one holding the stem ?
Either way the best idea is to strip it down fully. You take photos to remember what goes where.
8ABB39C5-7BFE-4DC8-BDC9-B64C5A010470.jpeg.fecfdafdfb34ada13a133ae731dae40d.thumb.jpeg.626c27cc225e5fe73a85db7e11b5aa14.jpeg
Edited by Chopin
That is an FL branded AS movement, possibly something like a 2066 or similar. Look under the  balance wheel to see if there is a number.
The set lever screw (which holds the stem in place) is the one to the left of the stem in your 3rd pic.
Thanks for the replies!  I thought that might be broken but I’m not entirely certain, that’s why I was looking for a schematic or a diagram. And I also thought that was the the lever screw too!;). It was different then the others but it didn’t budge either way.   The keyless works are definitely really gummed up so what I should do is strip everything down and clean the parts;  I should’ve started with a different watch;(.
You're in the right spot but it would appear that FL did a little more than just rebrand an AS movement. it looks like they made quite a few modifications and have removed the AS cal# altogether. It is fundamentally an AS movement though.
If you look on the Borel parts interchange site;
http://cgi.julesborel.com/
You will see that the FL1134 is essentially an AS1649 with parts from AS1852, AS1709, and AS1430, as well as some Zodiac 70, 72, and 76 parts thrown in.
Looking at your photos it looks as though @Chopin is right. It appears the tip has broken off the setting lever (the bit that @Chopin has circled). This should have a little stud on the end that protrudes down into a groove in the stem so that as you pull the stem in and out it pivots the set lever around its screw, actuating the sliding clutch. compare yours with #443 shown here;
https://www.oldswisswatches.com/watch-parts-branded/favre-leuba-calibre-movement-and-spares/favre-leuba-1134/
and you can see what I mean.
Borel lists this as a Zodiac part and says that it is obsolete, which means they don't have stock of it, however Cousins seem to.
https://www.cousinsuk.com/category/filter/favre-leuba-movement-parts
their part #FAV1164443
Hi I have attached the tech sheets mantioned by Marc, as you will notice by the notes in the margins there are variations for other cailbers so it looks as Mark says its quite a mix of other movements. hope this helps the cause.   cheers
31_UT6497.1,6498.1.pdf 1662_AS 1780, 1781_Smaller.pdf 2143_Zodiac 70.pdf 2144_Zodiac 72,72B.pdf 2147_Zodiac 76.pdf
I worked on a similar movement and they are of above average quality (mine was 36.000 bph).
Theoretically they are in-house movements but as has been said they're modified off the shelf movements. Was pleased by the performance so it's worth getting it fixed.
Out of curiosity how did they fabricate such a part? Milling?
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
    • A lot of it has to do with a generations attitude.  Have we reached a generation of folk yet that have no sentimental values ie. Just an object to sell . I expect my kids will sell my collection , maybe keep one valued piece. Not being in the game very long, i have no idea when the sale of old watches boomed or if it has even reached its peak yet. If we go back 20 years what were ebay sales like then, expense wise and volume ?
