Timegrapher Repair
Behrooz
Thanks John. I just thought may be you guys knew of a 3rd party offering diagnostics and repair services on these. Brand is TYMC. Sending it them for a warranty repair may turn out to be more costly than nuying a new unit. So, I was looking for US repair.
at one time for the mechanical type timing machines cleaning machines etc. there were people that service them for the most part they've disappeared. I have some links below of people who service equipment you'll notice one of the companies in the UK has just now quit servicing but he might be able to give you a clue as to where to get your machine serviced.
Chinese timing machines are interesting there appears to be at least two separate manufacturers that's based on my observation of how the machine's work. One of the companies you have the initials of tymc does or did at least appeared to physically exist. The other company conveniently really really hard to track down I might've actually at one time found them and just wasn't quite sure because of the Chinese English translation. Basically they put a variety of clever names on their machines and users guides conveniently zero addresses or anything of where they're located. but the quality of the surface mount circuit board seems really nice for an invisible company.
Tymc does appear to possibly still physically exist maybe. They used to have a distributor in Germany I have the image off their website which no longer exists. Amusingly the German company was unhappy according to a discussion I found in a discussion group a long time ago going by memory that the machines got cloned because the company making the machines sold components to another company which resulted in warranty repair issues for the cloned machines. so while the German site is gone there is a Japanese material house that claims knowledge of their existence but this is a very old webpage. Then googling the information there I come up with the second link which is extremely unhelpful..
http://osakawatchparts.com/aboutus.html
http://www.stylewatch.com/CompAboutUs.asp?CID=1255
http://www.electronicinstrumentservice.com/index.html
http://www.delphelectronics.co.uk/index.html
http://www.algo-sales.co.uk/repairs/horologicalEquipmentRepair.php
Because they don't make it. Just like Apple or Lenovo it's outsourced to the likes of Foxconn, just a lot smaller.
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
