Hi,
I have a watch with a two-piece leather strap. I love the watch, but i find the strap does not fit well. One hole makes the strap slightly loose and the watch doesn't sit right. The next hole is too tight.
I was wondering if anyone knew any tricks to make a better fit (besides getting another strap).
Thanks!
Is the strap in poor condition ? Maybe you need a new one.
Can you loosen the tight hole or do you want to tighten the loose one ? Try googling strap plastic/rubber tubes. Maybe those will help out. They go into the holes of straps. Mamy higher quality ones come with the tubes inside.
Hi,
Quote
The strap is almost new. It's just a stock leather one from a Seiko 5 automatic.
Quote
I suppose I could try to make the tighter hole bigger, but I worry I'd damage the strap.
Quote
About the tubes, is this the kind of thing you'd use on an older strap with stretched holes?
In time, wearing the strap, the material should "normalize".
As long as you don't use anything pointy or sharp you shouldn't damage the strap. Maybe use a toothpick or something and slightly try and loosen up the hole a bit.
The strap tubes could be used on any strap you want. I can't seem the find the plastic or rubber ones, only metal, but they do exist.
Before you mess with making holes in the leather, which would probably  end up giving you one ratty hole investigate other buckles. different styles will be shorter or longer
Thanks for everyone's suggestions!
The other idea I've been toying with is getting a leather nato-style strap. Has anyone had experience with one? I understand you have more fitting options with those. Finding a decent quality one could be challenging amongst the sea of nasty ones I see on ebay.
