24CF9EF3-714D-4397-AAB6-221D04C4D087.thumb.jpeg.7c23d9d721a30c3e7614b6dc4276cd7a.jpegB48DE094-B0A8-4579-A3F6-30771DB5ED64.thumb.jpeg.3bca56899d9f496933147607ff45d41a.jpeg7A07D2DD-0A51-4D0C-A391-272D43B97625.thumb.jpeg.0b0ceafb8b9b34b6cb3bfb415c57dae5.jpegHello, I’ve acquired (by that, I mean, I think I bought on eBay) a couple of these beauties with every intention of having them running in no time.  Eventually you’ll notice that this is a sad theme of mine.
One of them I thought to be a Ventura but now I think it’s a Pacer. The thing is though, I don’t think it’s got either of those movements inside!  I’m going to put up some pics for everyone’s amusement. Is anyone Out there a Hamilton fan?
     years ago,  someone in the east bought up all the new parts.  i heard the prices were enormus.   vin
Hi Longline   The movement you have in the photo is a shiojiri, owned  by epson seiko  I believe Perrins/esslinger in Canada and America have complete movements.
Shiojiri Y573A        Vacheron_nl on the ebay has movement at $10.99.. he seems to have quite a bit of shiojiri and   epson ,
Hi  Hamilton auto;s used ETA movements so it is possible its is as fitted, manufactruers of watches use all manner of movements in their finished product. The name on the dial is usualy the finisher .   example   Boss. Kalvin Klien, Micheal Kors etc. Its always best to check the movement make and caliber when working on watches reason being if spares are required its that information that is required
2 hours ago, LonglineOjoe said:
Thanks Watchweasol!  This can’t be the original movement though, right?
I was kinda hoping your response above was a joke and you're not seriously asking if that's the original movement?
In case it's a serious question that most definitely is not the original movement the original movement has a balance wheel and yes it has a battery also. The first link shows you what the movements should look like and if you're really curious get the book found at the second link.
http://www.hamiltonwristwatch.com/movements.html
http://www.hamiltonwristwatch.com/book.html
Well,  I'd like to play it cool and tell you that of course I was joking.....but it was more an expression of disbelief.  In the back of my mind I knew it had to be a 500 or a 505,  but I was distracted.;(  I did manage to get the movement separated from the case and dial, now need to see if I can scare up a suitable 505 somewhere.
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
