I recently serviced a Bulova 10BM from a 1917-H US Military Watch and cant decide if I need to redo it. The amplitude is solid but the rate is rather eratic over long periods like 14 hours. The watch has ran for several days now after servicing
This first reading starts a little bit after a full wind (so maybe it is caused by the mainspring weirdness that happens at full wind) and goes for 13 hours
This second one is somewhat later and covers 6.5 hours of run time. The rate is steadier but still has the 10 second deviations jumps.
Would you be satisfied with this for a watch from the late 40s/early 50s? I know a lot of people dont do long term measurements like this so am I just over analyzing it?
Quote
     a vintage like the one mentioned above does not have to be too acurate.  + or --  5 minutes on a valuable collector watch.  save the timer for a newer watch.    vin
I would suspect there is still some slight wear or perhaps dirt causing issues, but given the age of the watch, I personally would be reluctant to do much more to it.
Any idea what caused this little glitch?
Also if you look at the variation in the amplitude, it appears to have a very specific period to it. This suggests perhaps slight eccentricity, localized wear, or dirt on one of the wheels or perhaps the second or tube hand rubbing.
Depending on the regularity of this error, you may be able to figure its source out.
Military watch ? War time vintage?God only knows what stories it could tell. What it is telling me now, is that it is a well serviced , well worn watch.Speaking as an old Grunt, I would tell you that we don't like to be poked any more than is necessary.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
