Just now, TheFixer said:
Can anyone recommend a good Jaxa case opener in the region of £20 to £30.Or am I expecting too much?
Check this thread:
Edited by jdm
Hi  like jdm  I also have one of these chinese versions. Ok its not bergeon but it doe's the job. Like most things in life the justification for the expense is based on how much use is it going to get.   If you are opening lots of watches on a regular basis and want precision then get a bergeon if not then these are adequate .
I must say that with the better quality ones mentioned in the topic above I could open bazillion watches and a Swiss made one would not make any difference.
The real issue comes with extremely tight casebacks for which you want a bench opener, or at least an excelled holder block and a two handles opener.
I have tighten my  original Jaxa tool up by adjusting the spacers to as tight as they could be. Without making the tool hard to adjust.  I did the same with a cheap jaxa from Ebay .  They are a little flimsy as they are .
I use a two-handle Swiss Jaxa and find it opens almost anything. It's worth looking out for second-hand ones on eBay. I regularly open very expensive cases, so personally I'd rather use the best I can afford, and they aren't all that expensive.
https://www.ebay.co.uk/itm/VINTAGE-WATCHMAKERS-JAXA-UNIVERSAL-WATCH-CASE-OPENER/293326916000?hash=item444ba589a0%3Ag%3A99UAAOSwu~ldysXc&LH_Auction=1
Just put a bid on that.:)
