I have a bracket link that has a huge scratch in it (not the one in the picture) . Far too deep to repair. Is it possible to remove and replace the fixed links, the end one that sits in the case? How do you do it?
P
Post a good picture. What it may look "too deep" to you may be actually repairable. In any case, even if you were able to replace the end link, you may not able to obtain an identical one, exactly because isn't a separate part.
I have been told these links can be removed and replaced without too much damage. Apparently their is a specific tool to do it?
Does anyone know what this tool is? I read a few threads across forums and it's spoken about but I haven't actually seen it. The threads that do show how it is done have broken picture links so unfortunately no good. I would like to see this method for future reference.
If the pins are covered, being invisible to the eye there is no specific tool. One would need to precision drill and destroy the cap, then replace it it and polish together to the link, or fit a collet and leave the hole being visible.
This is one 'link' I found :-p
Bracelet at the bottom looks the same
https://www.minus4plus6.com/bracelet.php
7 minutes ago, jdm said:
Vise grips are mentioned, if you want to do that or any other brute force method that is, of course, entirely up to you.
I'm interested to know what the tool is. On various other forums it mentions a tool. Most of the threads I found are from around 2010 and dead.
Hi  There is a possibility that a pair of grip ring pliers ( the ones that open the jaws when operated)  could be used to prise the blind link apart. The ends of the tool may require modding to do the job. Or make up a tool to pry them open in the same manner.
I really think you'd better post a picture of the real bracelet you're writing about.
Sometimes scratches look like they can't be repaired but they can.
Envoyé de mon moto g(7) power en utilisant Tapatalk
7 hours ago, jdm said:
Here's the tool(s) the OP asked about.
https://www.aliexpress.com/item/4000222592506.html
nice find. Trying to visualise how it works.. i assume it clamps the bracelet either side and pulls it apart? The two thumbscrews on the top adjust height and the one at the end winds outwards to pull it apart.
i've asked around and not many people are aware of a tool like this? I heard Rolex use one and this must be the copy.
    • My name is George, and I am a passionate watch enthusiast, seller, and content creator in the watch community. I am very interested in expanding my skills in watchmaking,watch Design and repair.   I would love to inquire if you offer any mentorship programs, internships, or volunteer opportunities where I could learn directly from experienced professionals. I am eager to contribute, learn, and deepen my knowledge of the craft. Best regards, George M @watchmegobroke
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
