Help sizing mainspring
AP1875
I unwound a mainspring from an automatic chinese watch.
As I was greasing the mainspring the end snapped very easily.
I need to purchase a new one from Cousins.
The measurements I have are
1.43 high
1.12 thick
500mm long
I can't seem to find anything on cousins that's close to these measurements?
https://www.cousinsuk.com/category/mainsprings-by-list-watch-pocket
Is it important to get the exact size? How far can I deviate from my measurements?
Could I use a valjoux 7750
1.50 x. 115 x 600?
1 minute ago, oldhippy said:
What is the cal number? that is all you need.
It's a chinese clone, so unfortunately I can't rely on referencing the cal. the sizes won't be right. With the measurements I know exactly what I need.
Nothing matches up precisely on cousins so I am now wondering how much deviation I can allow for?
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
    • Latest 404 is this Baron which has a copy of a Seiko 66B movement in it, handy when I needed to find a replacement setting lever. Apart from the setting lever, crown, stem and new crystal (original was cracked) the watch is original. Finished result:
