Curious note inside case of family hand down
Valleyboy
20191013_142333.thumb.jpg.fe58b35d36b6d366a2237076774b500b.jpgHi there, a curiosity here.
I'm told this clock nor any part of it is any older than early 20th Century.
However,  my deceased father placed a note inside the clock that has details implying an older history.
I know my dad would have written the note based on something and in hood faith.
Any thoughts or theories much appreciated.
Not for sale.
Neil.
10 hours ago, oldhippy said:
Looks German 8 day wall clock with lantern pinions . About 1930's or 40's
I agree with OH, funny enough a clock that looks almost the same came into the workshop yesterday and the owner said to the staff that it was 1850's and handed down the family, I said it was around 1930's however leave it as we do not want to hurt the memory of the customer. This is common though, lots of people think their clock is older than it is, who are we to burst their bubble.
Another area is the value of the clocks, almost every time they over estimate the value by a long way, I will only tell them (through the staff) if the value is way below the repair cost, however sentimental value has no limit.
  • 4 weeks later...
7 hours ago, Collomps said:
I have a very similar clock. it works with weights, 2 meter tall, and it has all the design and styling as this one, mine is dated 1882.
The one mentioned above runs on springs. To be fair too you yours is different. If you can put up photos we can id it, need photos of the movement and case.
    • Hello from the Mid-Atlantic United States. I've been in the hobby for a few months and have concluded that I will be staying in it for a while. I've started to get some proper tools and I am looking forward to developing some skills. My current goal is to get comfortable enough to service / repair some watches I've inherited from family members.  My current project is a Mentor pendent watch with a BF866 movement that belonged to my great aunt.
    • Success! The watch is working, albeit not perfectly. I need to install a new mainspring. It only runs about 16 hours. Still, it's my first cleaning and rebuild. I bought it from the original owner's son on eBay! The other one was bought at a flea market. I needed both to complete the project. The model with a seconds hand had soldered watch band pins and I couldn't drill tiny holes so I used the flea market Waldan, which was nearly a perfect match. I also replated the case with nickel, but the result was subpar. It's never as easy as it looks.
    • Thanks guys. It's a Seawolf 10ATM pre spring bezel. The case knife stressed me a bit, but eventually got it off and cleaned - nearly seventy years of grime.  Thanks.  Cheers John
    • Exactly. This is a pic of the hairspring I'm working on. My horizontal v vertical rates are all over the place. There is no discernible terminal curve. My problem is that the outer coil is (possibly) hitting the regulator pin. It's hard to tell but it looks to be getting very close. Also getting close to the stud, which could be @VWatchie's problem. You can see that I need to adjust the inner coil to centre the collet. That will hopefully solve the problem. But then I'll take the spring off and attach it to the cock to see how it looks.   I don't know if it's causing your problem @VWatchie, but I would say your inner coil looks like this
    • Welcome to the forum.
