Hi all, I'm Callum and I'm a student living in Scotland. I have taken an interest in the hobby of watches and particularly watch repair, having always loved modelling and also repairing things, it seemed the perfect progression. I'm currently doing my best to learn the terminology, naming of parts and everything that comes with it, so apologies if in any of my posts I seem a bit vague or like I'm lacking in knowledge, that's what I'm here to fix! (Well that and my watches!)
Hope to eventually learn enough to be able to give advice and help others out, but will walk before I try to run
Thanks to anyone who helps this novice out!
Hi and welcome to the forum Callum.
Eternaltools.com list parts of a movement and their names according to eta. Their new site just lists tools and stuff they carry. You want ot visit the old site.
Best
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
