Making a Lathe Pully
jdrichard
You might find that the belt slips with that groove shape, generally for pulleys used with round belts the angle should be between 35 and 60 degrees, more towards the smaller angle. Most I've actually measured have been between 40 and 50. The smaller angle makes the belt wedge into the groove, so you don't need excessive belt tension.
I was to make the same comment but I didn't, as jdrichard is an able machinist and will figure out, without the need for any book.
However it seems to me that the original pulley have radius concave grooves, but the pics don't show clearly. I suppose that turning Acetal that can be easily achieved by grinding a round nose tool.
Please excuse if I'm talking without sound experience, I still have to resume my machinist self-learning with the new steel bars that I just bought for an hefty price to me.
Pulleys for high-confidence applications with wire rope (cable) are often round looking in cross section but there's a fair bit of engineering in the actual shape. All pulleys wear over time, I can see a round-ish wear pattern on many of my old machines and motors. I don't recall any watchmaking equipment that came with round grooves though.
Great tip, thanks.
Thanks. I take ALL advice and tips. The belts I have made so far are great and do not slip: so far.
    on a v belt,   the shape is not as importand as useing a type of grease on the belt, often AND; dos  not   need excessive tighting.  cheers,     vin
What grease would I use on the belt to make it grip better?
   "belt grip spray", i have used it but dont remember the name.  and a couple solid  rods.  but;  here is the secret --- bar soap.  an old flat belt leather trick.  good  on old auto v belts.  im shure they still sell that spray and less chance of loseing a finger.    vin
3 minutes ago, nickelsilver said:
I know it sounds crazy, but for round belting like us guys use beeswax is fantastic. Seems like it'd promote more slipping but it doesn't.
    leather or rubber belts?      there use to be round leather for sowing machines.    vin
The leather I use is boot lace and it is square, but the lathe doesn’t know it:) It’s diameter is good enough to provide grip and I have not needed any grip spray or treatment of any type. I get no slip when cutting a part. You can get it from Amazon for 8 bucks and sew it together with fishing line: like on my YouTube video.
   good show !
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
