Smoothing versus cutting broaches: Do I need both?
rduckwor
You don't need a  smoothing broach for a hand. The smoothing broaches are for smoothing the in side of a bush. These ready to use bushes, the brass is so soft a cutting broach is all you need, if you look in side the bush after cutting it is left smooth so much it looks as if it has been burnished. That is all a smooth broach does, is burnish.
Always use good broaches, they will always keep there cutting edges. Cheap won't last long.
4 hours ago, rduckwor said:
I need to clean out the pipe on a second hand.  Smoothing versus cutting broaches?
Thanks,
RMD
Well, A cutting broach will, of course, make the hole larger and so if you wish the hand to still fit the pivot then smoothing broach is the way to go, depends on if you want to remove material or not ;) but be careful, even though they are smoothing broaches they may still bind in the hole as you turn and you run the risk of breaking the hand.
To be fair, I have found smoothing broaches useful for clearing out stubborn debris. I remember finding what I suspect was glue in a seconds hand pipe once and couldn't use acetone due to the hand being painted.
@rduckwor I have merged your "dual post" as it keeps the forum cleaner. Kindly be patient in waiting for other members to respond rather than opening new topics with the same subject matter - many people are on different time-zones - have jobs - or are simply spending time with family ;)
    correct me if i am wrong,  broches come in a set.   "roughing and smoothing".   vin
30 minutes ago, oldhippy said:
Normally in sets. The very large clock ones can be bought separately.   Interesting to read Marks view about glue in the pipe, not come across that before.
'nor me since! Some silly sod's attempt at securing a loose fitting hand. Granted about 15 odd years ago but silly stuff sticks in the mind :D
I have use a pin vice for chronograph second hands, you can do it, but only if you are talking a couple of hundredths of a mm.
Go slowly tighten only a little bit and test fit, easy to close it a bit more, real PITA if you go too far and have to open it out again with broach.
Bergeon of course sells a special tool to do this if you have a few hundred pound spare, else get by with a pin vice, just make sure it is a good quality one that closes evenly so all sides (or 4 spots evenly spaced) get closed in evenly.
Ugh.  I see broaches are not free either.
Something else to add into the "Want List".  Projects get set aside until I can get back to them and I am running out of room as I go broke!
But I'm having a fantastic time.  Thanks Mark!
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
