I'm positive it should be mounted on the cannon pinion. I have the feeling I got the right cannon pinion but there is just no friction between the staff and the pinion. If not please tell me.
So, if i wanted to tighten it where do I tighten it, on the place in the picture?
Gently and small steps.
I will do that, I hope I learned a lot from my first attempt :biggrin:. By the way, thank you guys so much for helping me with this.
Like Daddy used to say, “advise is worth what you pay for it. It will be your success or our failure! Good luck!!
Yes right where you show, the arrow.
That means i'm learning allready! Thank you, I will try it tonight. I've bought a pair of nailclippers and are going to file away a gap.
Hi   I think we are missing something here, the cannon pinion is driven from the adjacent wheel and once fitted the HOUR WHEEL fits over the cannon pinion and engages the smaller gear on the same gear onto which the canon pinion engages.  The cannon is free fitting on the 4th wheel shaft which carries the center seconds shaft and is driven by the gear. cannon number depending on height is 1218 to 1220. hour wheel number is again depending on height 1231 to 1233.  So in short just fit the cannon and fit hour wheel over it. The min hand fits the cannon the hour hand fits the hour wheel. On a lot of older watches the cannon is indented and friction fits to the center wheel shaft and is driven by the same. Do you have the hour wheel for this movement.
Hi, yes I have the hour wheel for this movement. See the pictures below.  As you can see there is just enough space to fit the minute hand. So thats fine. However are you saying the cannon pinion needs to still be friction fitted to the center wheel shaft?
IMG_20190914_194210.thumb.jpg.536a80fbdf760e7ebc4e8dc514253cd5.jpgIMG_20190914_194137.thumb.jpg.bbd8a24045f2a74a25520f934ae435ab.jpg
Hi  No what I remember is the cannon is free running driven from the large periphery of the minute wheel and the hour wheel is driven from the smaller gear on the minute wheel. what I would do is to assemble the watch with the top plate fit the hands and put a turn or two on the mainspring then let it run, If all ok and the hands drive ok then fit the dial and re-run the watch uncased under a glass/plastic cover and see how that goes, do not at this stage maul the cannon pinion. The time loss could be down to a dirty movement /old oil, there are a number of reasons.  Have you dismantled and cleaned the watch or is it as it was purchased, It the best bet is to service the watch and check the rate then lets just see where we go from there before altering anything. These Omega's are fine movements so be careful.
Watch weasel is correct. I “assumed” the watch was cleaned and serviced and this was a reassembly discover issue. My very bad!! And I loath that expression.
How strong is the amplitude?   How much time loss per 24hr?
Is the time loss continueous? Or runs the hand for sometime and stop moving the hands?  How loose dose the crown turn in adjust position?
This is not a fixed center tube, I see a center jewel for the center tube/shaft to turn inside , Therefrom, the tube turns the canon pinion which turns the reduction wheel( min wheel), so some friction is needed between the tube and canon pinion.
Canon pinion is not friction fitted  on the tube, however some criction between the two is needed or the canon pinion  just slips.
The problem is: the minute and hour hands don't move at all when I wind the main spring. However when i pull the crown and adjust the time, they are moving fins, but they are moving very fast, like how a loose cannon pinion feels.
Dose the center tube ( arbor/tube    canon pinion mounts on) move/turn by the runing of the movement?      If it dose, gear train is delivering, at the tube, which is what its suppose to do. In which case tigthening canon pinion is in order.
Hands can be moved through the crown in set position, regardless of loose or good canon pinion/ center tube interface.   Regards
44 minutes ago, Purra said:
Yes it does turn
So, slippage at the canon pinion is the very likely cause.
Edited by Nucejoe
No reason to suspect anything else at this point
Yes I think that also, so you were telling me it needs to slip, but not very tight. I also just cleaned the center tube with lighter fluid.
Edited by Purra
Yes at one hand,  the canon pinion is to have some friction at interface with the center tube, to transfer the motion to min/ side gear and at the other hand it should let motion from the min train to take over, so we can set the time.
Have you seen the illustrated  glossory of parts and their names according to ETA?
Eternaltools.com/blog/swiss-eta-watch-movement-parts
Helps with a common vocabulary for parts names.
I think that  excess oil/grease on center tube caused the slippage with the old canon pinion.
In case it turned out too tight, I would oil the canon pinion interface, turn manually with the crown.
Sometimes you would need to broach the canon pinion if too tight, so appraoch the suitable friction in small increments.
Once you do this, you feel master at it.
On 9/14/2019 at 9:33 AM, Purra said:
I ordered a new cannon pinion for this cal. However when i'm placing it it doesnt need any force to place. It drops right in place.
Then either it is not the right part for the tube, or the tube is severely worn out and would have to be replaced as well - that would be strange but not impossible. To check you would have to inspect with a microscope or high-mag loupe, and/or measure with a micrometer for a known correct size.
Quote
Could it be that even the new cannon pinion needs tightning?
No, and I recommend that you don't do that. These are supposed to be quality parts are manufactured precisely. There is no amount of oil/grease that can cause the cannon pinion to lose its designed friction to the tube, or regain it in case isn't there.
Edited by jdm
4 minutes ago, jdm said:
Then either it is not the right part for the tube, or the tube is severely worn out and would have to be replaced as wheel - that would be strange but not impossible. To check you would have to inspect with a microscope or high-mag loupe, and/or measure with a micrometer for a known correct size.
No. These are supposed to be quality parts are manufactured precisely. There is no amount of oil/grease that can cause the cannon pinion to lose have the designed friction to the tube, or regain it in case isn't there.
Okay, thank you. Since the old cannon pinion was also losing time i'm starting to think my tube is worn out. Now that cannon pinion was relatively easily replaced. If I wanted to replace the center wheel, would that be a repair I can do myself?
Canon pinion is of the same quality as the severly worn out tube, which we oil at the jewel it to reduce friction and wear of.
Canon pinion itself is our micrometer showing loose center tube- canon pinion engagement.
Replacement with new canon pinion is ofcourse the prefered option.
Regards joe.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
    • Hello, looking forward to participating on the forum here! I will mostly be listening and asking questions since I am an amateur hobbyist. I have most of the beginner hand tools and a Timegrapher. The extent of my tinkering consists of a successful Seiko 7S26 to NH36 movement swap inside an all original 1997 SKX007, along with a bunch of battery changes for friends and family. I have yet to tackle full disassembly and cleaning. Right now, I don't really have the budget or time to invest in a cleaning setup (even manual cleaning), but hopefully soon! I joined because I recently purchased a mechanical Timex Camper from 1994, and my searches for information regarding servicing and swapping out these Timex mechanical movements consistently led me to Watch Repair Talk. There is also a wealth of knowledge here about dial design, another area of interest for me. My other hobbies includes leather working (mostly small pieces, shoes eventually), crochet, sewing (would love to make clothing), design (especially type design), home espresso, cocktails, and tennis. I want to buy a film camera, but I don't need yet another expensive hobby involving last-century technology. Yes, I have ADHD.
    • HWGIKE#60 Accurist ETA 2390 Swiss lever, 21 jewels, full service A slim Accurist with a nice movement, eventless service, nice performance.
    • Hello and welcome from Leeds, England
