Brac Cal 107 balance jewel.
There must be a reason why that got bent , if dropped it could have caused other damage & it’s never good to try & straighten anything still in the movement although it’s probably not hardened. Dell
I can tell by your question that you are having doubts and that you feel disassembling it first is a safer method. Good thinking! 😉
I don't think doing it in situ is possible, it also needs a service, it's filthy. -
Not surprising really, the shock protection has gone but the cap jewel, which the pivot runs against is in place. Ugly attempt at repair though. -
So I’ve been doing this washer trick for a couple of weeks now and I have to tell it it is genius — haven’t fouled a single seiko mainspring since. Thanks again.
