Valjoux 7733 Service
Khan
Hello
I have for a long time been excited about servicing a chronograph. Are there any cautions I should be aware of? I'm pretty much used to service different manual and automatic swiss movements. I can't find a video or manual for disassembly procedure. What movement is it familiar with?
The 7733 is a pretty easy chrono, especially with a the tech sheets. The thing I've seen that trips people up is the start/stop lever is pivoted and on two planes, and has an integral spring. It can seem counterintuitive to get in place correctly so pay attention when disassembling how it's setup.
Hi again!
Regarding chronograph runner:
I managed to take the movement apart and assemble it, thanks to the knowledge shared and available. It runs like a dream without engaging the chrono. When chrono starts, it still runs good for 10-20 sec. And stops immediately. I can't see what's preventing it to run. The train wheels should be aligned enough. No lubrication in forth wheel, minute runner and sliding gear wheel. A drop of 9010 on top of chrono runner and lower pivot. It's black on the pivot shaft, is it worn out (teeth seems intact)? And should I use 9501 on the chrono and minute runner contact area? Its shown in service manual but not mentioned elsewhere here.
Edited by Khan
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
