Received and stripping my first jump hour.
The movement is no trouble. A simple 1 jewel pin pallet but the date/minute/hour (from the outside in) wheels are not budging. (Central pivot for seconds hand).
I suspect it has to be pulled off something akin to a cannon pinion but this being a particularly nice watch I want to wear I don't want to risk damaging it.
It's a Trafalgar Instantime.
Any pointers or ideas would be gratefully appreciated.
Thanks.
Yes, the seconds are friction fitted and can be removed using a pair of hand levers or .80mm screwdrivers inserted into the small slots seen in the picture.
Apply steady,  upward pressure...not too much because the seconds disc may warp if you push up too hard. Slow and steady. Here a link to a jump hour overhaul I did a few years ago
  • Thanks 2
Thank you, this gives me a bit more confidence to attack it again tomorrow.
I'll take a look through your service link.
Much appreciated.
Have taken a look through and that is perfect for my question. It looks to be near enough the exact same movement, though yours is a bit posher, it has a jewelled pallet fork pivot. :)
thanks again.
Edited by m1ks
Huge thanks to Joe above for the centre wheel removal pointer. Much appreciated.
Watch serviced and ticking away nicely with acceptable accuracy for this movement.
Collectible piece.
3 hours ago, Nucejoe said:
Wow, this variant of bfg866 is ultra rare, the crytsal, dial.
Yes this one has three mag windows in the crystal...I used to have one of these but sold it a while ago.
J
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
