need service manule
vinn3
3 hours ago, Nucejoe said:
Valjoux 724 was produced for a short time and was replaced with 729 .
Manual of which would do, If you can find one.
Ni
   thanks;  that answers a few questions in my search.!  the first  is which screw holds the stem in.
To release the stem you loosen the lower one of the two screws by the stem.
I attache a service manual to the 72 but unfortunately with the wrong complication but in the 60's the tech sheets didn't always be the best.  ;)
If you need more help it's better to continue in an other thread.
Valjoux 72_88_721.pdf
Nivada:  The 30 mm mvt. is out of the case and stem "set in place".   you might notice,  i had to remove one of the levers to get a straight shot at the secont case screw.   i'll replace it and move on to cleaning.  vin
    steping back from a complicated mvmt. repair;  i opened  a 1950's west clock wrist watch.  German made case and US mvmt..  it has a very unique stem set lever.  one of the 4 scews holding the back plate holds a lever attached to the stem set pin.  vin.
33 minutes ago, Watchtime said:
Westclox was founded in 1885 In Illinois by Charles Stahlberg and wellknown for the Big Ben and Baby Ben alarm clocks...They also had a plant in Scotland...
    thanks. i've delt with" the bens"   years ago.  did not know of a wrist watch.  the alarm clocks are still sold in the U S , but,  they are bad,  half plastic  and the alarm off button is bad too.   its marked made in u.s.a..    i wounder?     vin
  • 2 months later...
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
