I didn,t see where the remaining part of my post fell off the wagen, here we go.
Nicklesilver says 72,  dose that includes the variant 729? Very close in the family though.
3 hours ago, Nucejoe said:
Valjoux 724 was produced for a short time and was replaced with 729 .
Manual of which would do, If you can find one.
Ni
   thanks;  that answers a few questions in my search.!  the first  is which screw holds the stem in.
To release the stem you loosen the lower one of the two screws by the stem.
I attache a service manual to the 72 but unfortunately with the wrong complication but in the 60's the tech sheets didn't always be the best.  ;)
If you need more help it's better to continue in an other thread.
Valjoux 72_88_721.pdf
Nivada:  The 30 mm mvt. is out of the case and stem "set in place".   you might notice,  i had to remove one of the levers to get a straight shot at the secont case screw.   i'll replace it and move on to cleaning.  vin
On ‎8‎/‎30‎/‎2019 at 5:34 AM, vinn3 said:
thanks;  ill try that this morning.  vin
     the stem came out with only 1 1/2 turns.  thanks all, for the help.  vin
    steping back from a complicated mvmt. repair;  i opened  a 1950's west clock wrist watch.  German made case and US mvmt..  it has a very unique stem set lever.  one of the 4 scews holding the back plate holds a lever attached to the stem set pin.  vin.
Westclox was founded in 1885 In Illinois by Charles Stahlberg and wellknown for the Big Ben and Baby Ben alarm clocks...They also had a plant in Scotland...
    thanks. i've delt with" the bens"   years ago.  did not know of a wrist watch.  the alarm clocks are still sold in the U S , but,  they are bad,  half plastic  and the alarm off button is bad too.   its marked made in u.s.a..    i wounder?     vin
  • 2 months later...
