I have a Waltham 6/0 1942 Military watch that has a bad Balance. Regulator is missing and Hairspring is fouled. Finding a replacement is almost impossible(at least for me) so I'm left with attempting to rebuild. All comments and advise appreciated.
Many may call it a goner, I have however recoiled many. It is thick and easy to work on. Some advice if you decide to give it a go.
You need finer tweezers than what you are holding in the pic.
Unpin the h/s off of the stud.Remove the h/s. Insert a safety pin through the collets hole and pin the h/s on a white sheet of paper.
Start from the collet outward.
Do not work on it more than ten mins at a time. Give yourself time to think about what you done and what is to be done next.
Keep in touch with me as you proceed.
Best regards
Hairspring is not specific to a movement.If the aim is to fix the watch and not neccessarily practice h/s manipulation. You can fly a hairspring of close specification  to the proper frequency.
Regards
