F(R)olex balance repair
I’ve been asked to fix a Folex Daytona Chronograph for a friend for sentimental reasons. I’ve found the issue is the missing pin on the balance pivot. Does anyone recognise the movement and advise where I can get a replacement- if they are available?? I’m UK basedbc14b4d9123e7dbbec2364822e881e1b.jpgeec408e217f5d21c520be91b2b1ce05f.jpg
3 hours ago, carlos123 said:
Do they do a chronograph version? This one is supposed to be a Daytona.
Trying to bring it "closer to original"? Unfortunately mechanical chrono isn't an Asian specialty, nor economical.
Edited by jdm
I’m not even sure the chrono element is actually meant to work [emoji23]
1 hour ago, carlos123 said:
I think that sentimental value is well preserved as long one has the piece. Your friend should accept it for what it is and be happy to have you trying to repair it somehow.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
