Damaged screw head
Hi.  I picked up a fossil watch for a couple of pounds that hopefully only needs a battery, but one of the screws on the back is almost rounded off and doesn’t want to budge.  What’s the best way to deal with this?  The case is plastic so the screw is not rusted in.  I’ve resisted the temptation to put any sort of lubricant on it until I know what I’m doing.  Spa you suggestions would be gratefully received.  Thanks,  Al.
Hi  If the screw head is accesible try to cut a groouve in it with a fine knife edge  file to ceate a slot. Its not beyond some people to glue in a duff screw.  With a plastic case be very careful what you use to loosen the screw.  Be assured some body on the forum has had the same problem and will know of the way to proceed. good luck
Thank you for the reply.  Its a bit of an odd solution, but I wonder if anyone has tried solder to build up the screw or even soldering a screwdriver to the screw to gain grip.  I’ve got a colleague who can solder joints that I can barely see, so if it’s worth trying, I know just the man to ask.  Good idea, or not?
Hi  trying to solder a screw which is encased in plastic is frought with danger as the heat from the iron would cause the plastic to melt and worst case ruin the watch  proceed with extreeme caution if you follow that route. Another possible is to use a dremel and drill the screwhead off leaving a small stub to be removed with pliers
Thanks again for the replies.  I’d arrived at the “drill it out” solution but I’m still reluctant in case I can’t get the stub out.  I suppose, worse case it may end up with 3 screws holding the back on which isn’t the end of the world.  I hope it only needs a battery. Cheers.
Being plastic it shouldn't be overly tight. You can try using a flat blade driver with a sharp edge to help provide the grip on the edges as you loosen.
If it won't budge at all then carefully and slowly grind the had with a dremel. This will leave a stub protruding once the back is removed which should come out easily.
In assuming you've loosened the other screws and confirmed it is screwed down and they're not moulded in cosmetic heads?
This often happens with fashion watches and they're a pop off case back.
13 minutes ago, mlfloyd1 said:
By some screw extractors from Esslinger.
A screw extractor may work (assuming it's a real screw) but is kind of pricey for an one-off job on a doubtful watch..
BTW Esslinger is an US seller.. I gather the OP is in the UK.
    • With something like this a gasket seal for instance if i cant find the relevant information i would use instinct to decide what fits and works best. You have the original gasket ( well maybe its original or hopefully it is )so its fairly easy to determine what material to use. Shape , for that i would look at the gasket seatings, are there grooves or recesses in either the case back or case or both, what shape are the grooves, flat or round etc, how does the gasket sit and behave in those seatings. Next thickness,that is going to be a bit of a guess, especially if the gasket is a soft one that has been heavily compressed over time. This is where a selection is going to come in handy, personally i would be choosing one that is giving me the feel of compression as its coming into contact with both of the mating surfaces. But not so much that the gasket is going to squash out and become distorted, again this is guesswork and feel is required with the allowance of compression over time, something you may want to check after six months. This part is a little moot as without a pressure test, good water resistance is not assured so the watch needs to treated as such and not as if it were a new diving watch ( not that i would treat any new diving watch as if were ). What you want to expect from your efforts is a little accidental rain catch, if you want more water resistance guarantee then a professional gasket replacement and pressure test is what you should be seeking which will be more than the value of this watch. Coincidentally i have the same watch, been searching for a stem for it for a while now.
    • It might not be a hook it might be something like this. But still the mainspring is catching on something on the slip ring because it doesn't have its own outer slipping part like the modern ones. The image below came from some vintage Omega thing I'll have to see if I can find where that has gone to.documentation A different book has this
    • I did not see a hook on the slip ring. I will check again tomorrow.
    • I think I'm having a confusion here? You would apply the breaking grease to the inside of the barrel then the slip ring would go inside. Then the mainspring goes in and it catches on the hook on the slip ring.
    • Thank you for the once again very thorough and informative reply. I'm sure at this point it's academic, but I'm always curious to know best practices. This then implies that If I'm planning to reuse the old mainspring (which I am), I should also reinstall the slip ring. I will do that and apply braking grease to the inside of the slip ring as if it were the barrel. This makes the most sense to me. Also, that bit about the center cannon pinion is very helpful. That wasn't in the tech sheet I have (attached) dated 1970. Omega 1001(1).pdf
