I've been working on this for a while. My wife's due to give birth any day now and this is what I'm going to give her after the baby is born. This is my first attempt at restoring a dial. HSL was kind enough to send me a spare one to practice on. Which I did, and it ended up being the final one I used. What was also interesting, I attempted Mark's laser printed logo method.Which worked surprisingly well. The edges of the print aren't quite as sharp as the original. But you would have to have a very expert eye to tell the difference. I think with a very high DPI laser printer you could get this more or less perfect.
IMG_1811.thumb.jpeg.e9a129d0a23212b26dec62a345353d4c.jpegIMG_1810.thumb.jpeg.825e76da306dce7094648ec10ea1ac08.jpeg
I think small movements are great to learn on. Large movements seem so much easier now.
It's just steel but it's nicely made. Not original.
I agree. After working on tiny women's movements, full size movements feel like pocket watches.
Is there a before picture? It looks really good from this perspective.
Hopefully this watch will mean more than any off the shelf gift could!
Sent from my PH-1 using Tapatalk
This was what it looked like from the original eBay listing. The movement was also really rusty and nasty. It was a fun project bringing it back to life!
Wow that's an improvement! I'd like to try this one day, I probably need a laser printer first.
The only issue is I tend to like darker dials and you can't deposit white unless you make the whole thing black and use a negative logo. And that disregards color too.
Very nice..The IJP doesn't do white. It relies upon the paper for that. So you paint the dial the background color you want ,and print the decal so it has a white  background .
One option for white is to use a toner reactive foil. This is what I used with success: https://www.circuitspecialists.com/pcb-trf-white.html I didn't use decal paper for printing but used toner transfer paper. My presumption this would still work with the film-less decal paper.
Getting the toner reactive foil to work is tricky though. It requires both heat and pressure. Too much heat and pressure and entire dial turns white. Too little and it would only partially stick. It also requires some brushing to remove any bits of foil left over. It took a lot of time, practice an patience for it to work for me but it is certainly possible. I wouldn't recommend this on a dial you only have one-shot with, try with a blank you can practice with.
    • Link below shows the tool used to push the stud out. You can make the tool , just file a screwdriver to this shape.  https://www.esslinger.com/bergeon-16918-etachron-stud-remover-screwdriver/ There are vids on YouTube showing how the stud is to be  push out. Shouldn't get over creative, just go by this approach.  Good luck.
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
