Great Weekend
Amazing drink Mark, pity you can't send one over! They look sooooo good! We'll start celebrating later on but in the meantime we get ready with the occasional fruit cocktail, "sangrias" and "mojitos": favorites here in Miami!
Geo, what is in that cocktail you mention, I'll make one if you list the ingredients...hope it doesn't take much money to make! :)
Noel Coward said that, to make the perfect Dry Martini, you pour a large measure of gin into a martini glass and wave it vaguely in the direction of Italy. My favourite mix is given below:
Will's Dry Martini
1. Put plenty of ice into a cocktail shaker
2. For each person, pour two measures of Hendricks gin into the shaker
3. For each person, add one measure of Noilly Prat
4. Add a shake of Orange Bitters to the mix
5. Stir the mixture 20 times - no shaking, as it dilutes the strength of the martini
6. Pour into a martini glass and add a green olive - stuffed to taste
7. Drink
8. Have another!
Cheers!
Will
One martini, two martinis, three martinis...floor! :)
Mojito recipe:
  • 2 teaspoons sugar
  • Juice of 1/2 lime
  • 2 sprigs fresh mint
  • 3 oz. (90 ml) club soda
  • 2.5 oz. (45 ml) white rum
  • 6 cubes of ice
Add the sugar, lime juice and fresh mint to a tall glass
Add the sparkling water
Muddle the mint leaves inside of the glass. You can use a muddler or the back of a spoon.
Add the rum
Add the ice cubes.
Enjoy!
Edited by bobm12
Trip to Lile France today & tried hot beer & hot apple juice in their Christmas market and it was good as it was B. cold today . But in the restaurant my daughter-in law fancied Cherry Beer & actually it did not taste as bad as I thought it would.
We go over to Calais and Bruges - and Le Touquet - regularly, just for the crack. We never buy wine because my son's in the wine trade and gets 20% staff discount.
But we do come back with lots and lots of lovely Belgian beer... Leffe, Kwak, Chimay, etc.
Yes we are lucky because my daughter-in-law works for Eurostar and free tickets now & then. The wine is just not worth the bother but the food is wonderful. Always return with wonderful pate,s,cheeses & pots of crem brûlée is a must. Not keen on the Leffe beer find it a bit to hoppy.
Cherry beer - interesting!
I picked up some beer in Morrisons the other day which happened to have some chocolate in it. Didn't taste the chocolate though.
Might try some Disaronno mixed into my beer this weekend to get that Cherry taste, see what happens :D
DiSaronno is made from almonds [emoji6]
Ooh, Cherry S.C!
Not had that yet.
I like it. It may be me but it seems to have a heftier kick.
Neat with no ice.
Ok, guys, that's it, I'm getting a drink! :)
If you were closer I would join you :)
    • From the photo the pallet arm looks as if it has been tampered with the edges are not nice and straight this can cause problems on the banking pins.
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
