Scrollsaw Cuckoo Clock
GregC
Just started cutting this clock. I'm posting pics as I go to give me inspiration as well as motivation. Its not going as fast as other things I've done but it'll get there.  For now it''ll have a quartz movement  as I already have them sitting in a drawer soemwhere. When I see the dimensions of the finished product I'll see if I can squeeze a real cuckoo clock movement in the next generation if I'm still into watches and clocks by then.
2 hours ago, Squiffything said:
I am tempted Greg, just got to re-arrange the fitting of the saw to the lathe and I’m away.
Then again I could use the one down the shed.
It's not hard and you can cut up to 3/4" thick material. If u want details pm me
I finished cutting the body, the roof, the sides and the pieces for the pendulum. Whats left are the 2 support blocks,  bottom plate and the back. I started sanding and filing the pieces so maybe I could be staining the pieces soon and then assembling it.  When I get to the staining part is when I get excited as I know its almost done and I'm in the final straights.
Wondering now what is the size of a normal cuckoo clock movement and how many rods it would have. Anyone have info for that?
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
