I had posted this earlier, but realized that I was encroaching a bit on another thread. Apologies to Rogart63 for doing so.
I also realized that the question might be better off standing on its own, as it might be a common issue.
This is an update on AS1171 problem child.
I ended up cleaning the hairspring for the second time on this one, as it was running very fast. I didn't see the coils sticking, but figured it must be that. I had evaporated out of OneDip, so I just ran it through my standard cleaner. It wasn't enough. Since I had lost another yoke spring (Prior to my using the plastic-bag trick), I ordered it over da Bay.
Using the bag trick, I got the yoke spring in position without too much problem. A problem I have had with this watch has been that inserting the stem is a royal pain. It's a fifties vintage waterproof case that has the integrated pipe, upon which the waterproof crown fits. This makes it so the movement must be set in the case without the stem.  You then set it in through the pipe.
What happens is the clutch ends up shifting inside its channel in the plate. When you insert the stem the clutch invariably gets sideways and won't allow the stem to get in position. It's really trying my patience, as the watch is finally running great, and I'm being thwarted on the last step. I tried the stem once with the movement out of the case and it sent right in. It must have something to do with the lack of side to side play between the pipe and waterproof crown. Regardless, it's very aggravating indeed. I thought about removing the crown and using the bare stem, but I had used Loctite on the crown and it wasn't being easy on coming off.
The movement's design is much like other AS ebauches, it's just got a bad attitude.
Does anyone have any tips on dealing with this sort of stubborn clutch/stem mating? Maybe using a short dummy-stem to set it in the case to keep the clutch aligned properly? Is it best to put watch in setting position or winding position in such situations? Thanks ahead of time.
Edited by MrRoundel
Added crown removal thought.
As I reassembled the movement and pondered the "whys" of it all, I had a thought. There is a spring on the left side that is set into a recess on the top of the pillar-plate. I am placing the finger of the clutch-lever over the top of that spring. This would apply apply upward pressure on the lever, which is the same direction that the yoke-spring presses. I'm wondering if I am supposed to set the finger end of the clutch-lever under that spring (Red arrow) on the left (May be possible), so it is applying downward pressure to the lever, the opposite of the yoke-spring. Is that where my problem lies? Thanks all. Cheers.
Note:The image of the AS 1171 on Dr. Ranfft's site, appears to show that I have been doing it right, that the "finger" should be above the spring, applying upward pressure. :-/
Edited by MrRoundel
Added Ranfft comment
Yes they can get sideways on you pretty easily.very frustrating.let's see if I can explain how I do this.assemble everything correctly. With the stem in place. With the keyless works in the winding position loosen the retaining screw and remove the stem.This gives the parts less wiggle room.Place the movement in the case.. while reciting the proper chants and incantations very gently insert the stem..You will get it.just be patient.
Thanks, yankeedog. The first time I went to assemble it, I did have it in winding position. The second time I tried it in setting position and it indeed seemed worse. I'll go back to winding position, light some incense, and change up my chants. I appreciate your taking the time to respond. Cheers.
I ended up having to remove the crown and then "back it in" to the case with the stem in place. For some reason, the new seal on the new crown was inhibiting the necessary leeway to get the dang thing set. Once it was out of the case, and not subject to the stresses of the new crown seal on the pipe, the stem set in. I was able to get some small pliers to hold the stem while I tightened the crown onto it. It was really on there last time. Hopefully I'll get the same solid hold this time.
It was making me crazy. Thanks again for you help, yankeedog. Cheers.
Not a bad looking little booger. I ordered a Hadley-Roma band for it today. It should look good.
Of course now the little booger is running and stopping. The stem feels like it's not going solidly into winding position, so I suspect that it's not completely disengaging from the intermediate wheel, etc., and dragging on the movement. Bloody 'ell. I may have to get a new stem for it, an keep it a bit longer. Either that or find a deeper crown that won't get bottomed out.
First step: Pull it from the case and see if she keeps running,. Second step: New stem,. Third step: Dynamite. :crazysmile:
Breathe deep. you should be able to observe the winding operation with the back removed.if it is winding properly consider that you may have a bad mainspring. they can fool you quite easily.listen closely as you wind, you may hear a tick indicating that the spring winds for a bit then slips.additionally if it winds  forever and never gets fully wound , that wound be another indication. you could also wind it with a screw driver to test your hypothesis..the watch is a beauty. it is worth your effort
Edited by yankeedog
Thanks, yankeedog. I could feel that it wasn't allowing a complete disengagement. It wouldn't get a solid "click" when pressed in for winding position. I ordered another stem for it. I'll cut it a touch longer to allow more inward movement. It won't look as good, due to it's being further from the case, but it should work.
BTW: The mainspring is new, and is not slipping.
And thanks for thinking the little watch is cool. The hands and case are in pretty darn good shape, with minimal pitting, for the type and period. It'll look good with the new band.
Edited by MrRoundel
That’s a nice looking watch. The two tone bamboo dial especially sets it off. Hope you get the keyless works running smoothly and all problems resolved.
I ended up getting a new stem. I figured I'd try that before I filed down the tube. Well, so far so good. I got rather lucky, as I snipped the stem one time and got it right where I wanted it. Any shorter I would have been shortening the tube anyway. The wind/set transition could be smoother. However, since it's my own watch, I'll just live with it.
The watch is running now, and seems to be keeping good time over the past hour or so. Unfortunately, I did leave a little of my signature scratch on the dial up by the one. I was putting the case over the movement to protect the dial and let go of it too early. :thumbsd:Figures, right? If the watch really is fixed this time, I'll be happy, as I have very little into it money-wise. Time-wise well, that's another story,. Thanks to all for contributing opinions, tips, etc. Cheers.
Drive the tube into the case, instead of filing the tube, you would need to polsih the tube if you file, just so it wouldn,t tear the rubber seal in the crown.
The screwdriver shown in the pic next to your watch is the tool you need. Insert the screwdriver in the tube, its handle wont enter the tube, tab on the screwdriver on its head to dirve the tube in.
Another approach is to drop bits of metal in crown hole where stem screws in, bits of solder, aluminm foil, screw the crown on stem.
    • I was wondering because of the alum idea.
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
