Winding stem does not fit
By LittleWatchShop · Posted
By SwissSeiko · Posted
I do believe in one of the manuals I saw for the 2892 DD module, you could unscrew it from the 2892, and submerge the whole thing in your cleaning machine as a single unit. I havent tried that yet, but when I was having issues with my Omega 1140, I got lucky and found a brand new one in Poland, and ordered that. So, if someone needs parts from an 1140 Omega/2892, I have the chronograph module in my parts bin, although its disassembled.
