peter alarm clock
luiazazrambo
Hi *,
I bought a few clock on ebay as a joblot and this one was one of them. I just love it. It was soaking in oil and dirt. I have already cleaned and oiled the music player part and the clock is thicking down at the moment, it has a broken alarm spring though. It has a thorens music player and I am not sure about the tune and about the comb of it. Both the comb and the cylinder has the number of 3477 so they belong together, my question: should the comb have all of the teeth or was it produced without some of the teeth?
Ohh and I have the glass for the clock but it is missing for the ballerina, any idea how to get one? Or shall i just cut one from plexiglass?
Best regards,
Lui
11 hours ago, Squiffything said:
Replacement combs are available and it looks to be a standard 18 tooth comb. Not sure how available Thorens combs are.
Could not find any for thorens so far. The ones I see with 18 tooth are similar, but not the same and the devil is in the details. They probably would not give the same tune/sounds back. I might give a try as I have no options.
20 minutes ago, Squiffything said:
Excellent and if you get it at that price it’s worth the unit to make the clock “original” plus you have the box for another project :)
Yep, however I was worried about the weights at the end of the tooth on the comb. I knew that they must play a role and here we go:
My colleagues wold say RTFM. :)
5 hours ago, measuretwice said:
Very nice, that's pretty neat item.    I was hoping we were going to see a comb repair as I've a Swiss Music Box that needs work, including a comb repair, but it turned out very well
Well I don't think that the comb could be realistically repaired. I had missing teeth and even if I would have them I could not weld them back. If you look on ebay for thorens music box you will see that you could buy one for around 5 pounds plus postage (18 teeth).  So I did buy a jewlery box and then I replaced the drum and the comb in the clock music box movement. They come in pair as the weight of the end of the teeth specially formed and made for the drum to achieve the right tune. The rest of the music box was already cleaned and oiled. While I was searching for music boxes I could not help myself and i bought this for 3 pound plus postage:
For sure you went the right route, the one I have is like in the video below so its make a new one or or repair the comb.   I believe those that collect them do repair the combs, I just haven't pursuit it yet to figure out how.  So it sits on a shelf :)They are kind of a neat thing and got fairly elaborate as prior to the phonograph it was the only way to play music other than live.
Edited by measuretwice
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
