Troubleshooting question
Lc130
The exact angle depends on the position of each component and varies between watch mechanisms, but at rest it should be roughly like this.
If the impulse jewel is not sitting in the correct place, when at rest (no power in the mainspring), the watch will be out of beat.
The exact position of the end of the hairspring relative to the jewel depends on the design of the watch, but what you show seems incorrect.
3 hours ago, Lc130 said:
I'm still learning watch repair.  Are you saying that the impulse jewel should be directly across (180 degrees) from the beat corrector (HS terminal)?
Thank you
Early in the morning local time here. Just saw the pic.  True depends on design.
I say,  where would you say the fork is to be placed in your watch so the BW would come to rest in beat?
Thank you
Where would you place the fork in your watch, so your BW would come to rest in beat?
5 hours ago, Lc130 said:
It's in pieces at the moment.  This is how it looked before I took it apart and after I put it back together.  You can see the loose screw on top of the ratchet in the second pic.
Where do you place the fork so your BW would come to rest in beat?
Where would you place the fork so your balance wheel can come to rest in beat.
Thank you
Where would you place your fork in your watch, so your BW can come to rest in beat.
Thank you
8 hours ago, Nucejoe said:
The hairspring ends right in front of the impulse pin,  HS end is where the studs mounts on the HS. That is not right.
I also thought there were something strange there, but then I realized I was looking at a shadow of the HS that looked like another turn of the spring. Could it be you're also looking at the shadow?
Yes a closer look, I realized . thanks
Folks,  Sorry for the posting the same repeatedly, poor connection wont let me see if what I submitted got posted.
Well spotted, that is indeed the case. In that case the HS might be fine, but the balance may be not quite aligned correctly. Can we see the output of the time grapher?
8 hours ago, AndyHull said:
Also, is the hairspring correctly fed through the slit in the regulator?
In the picture, it appears to go behind the regulator slot, not through it as it appears to be running too  close to the shaft of the balance to be going through the slot. This may also be an optical illusion of course.
If this is just an illusion, then , set the regulator so the mark lines up with the centre mark between the + and - indicators on the bridge. Set the beat adjuster slightly closer to the bridge, as per the ranf example I linked to, and try again.
the stud should be on spoke, almost 90deg off. That alone is enough for a flight to nowhere.
This is not always the case. The stud in some case should align with a dot stamped on the outside diameter of the balance wheel. If this is present, it serves as a good starting point for reinstalling the HS or checking initial beat with the BW out of the movement
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
