Hello. I am trying to source a hair spring (does not need to be balance complete) for an ETA 2408. Could you please advise if the hairspring on an ETA 2390 is compatible, and for my own future reference, how do I find such information please? Kind regards, Deggsie
The hairspring often are matched by what they call vibrations, so the first you should look so it vibrates/oscillates at the same frequency. Next you have to match the diameter of the spring with the diameter of the balance Wheel. If they are the samme then it might work.  next you look at the balance staff, If these are the same the chances for success has increased enourmously since the collar on the hairspring will sitt tight on the balance staff.
At RANFFT you can find the most except the diamater of the balance Wheel.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk&ETA_2390
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk&ETA_2408
Edited by HSL
Thank you for your reply. It seems it will be taking quite a chance to buy the eta 2390 spring in the hope all the criteria match when I receive it. I think I will hold on an wait for the eta 2408 to come along on eBay. I might be lucky - no hurry. Thanks again, Deggsie
Compatable , a HS out of eta2390 fits on 2408, streigtht away also the space to accomodate the guest is readily available in the new surroundings, the main problem remains, the new  HS and BW team should vibrate to the design beat together, For instance to 18000 beat/ hr. That is how many loud beats we or timegrapher hears per hour.   At this point you are dealing with the length of the HS. The longer the length the longer the period.. To get the beat you need for time keeping of the watch, the only alteration at our disposal is to shorten the HS preferably in increments to approach and not pass by the 18000 beat/ hr vibration. Shortened too much, you need another HS to start all over.
You can vibrate balance wheel- HS outside the movement on a tool specially made for this purpose or vibrate inside your movement.
If the new HS is already too short, it should go back on 2390. You have just lost a bit of the factory poising.
Regards
If you decide to wait Otto Frei has sometimes good tips and trix in how to choose things and in this case they have written a couple lines about it on their page, Reading is Always a good past time.
http://www.ofrei.com/page820.html
I'm guessing the part you're looking for is the incabloc and not the  KIF? The part number for Incabloc ETA balance wheel with flat hairspring is 721.
When I put this part number into Bestfit, this is what I get for possible replacements:
MATSYS says only difference between  2390 and 2408 is that Rolex/Tudor uses same balance assembly (2402) with KIF shock protection for its 21Jewel version.
Hello all. This forum never ceases to amaze me by the way people are so willing to help out. Thank you so much for all of your very useful replies. It certainly helps to know that the ETA2390 HS will be a ‘direct’ donor part into the ETA2408. whilst I appreciate what NuceJoe is explaining about needing to set the length to establish the correct vibration period, it seems in this case that the HS will not require further adjustment? Is that correct?
And to clarify, yes the BW has Inca shock system. [emoji846]
Many thanks again!!
Many thanks again!!
I don't think you'll need to adjust the hairspring.
J
Worked as best as I could have dreamed. We get this balance out of the way and hear about a proceedure to vibrate HS.
Regards joe
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
