They things come in three,s Well here goes:
1.
Fitted a new oscillating bearing to a watch & clearly it was faulty so re-ordered.
2.
Ordered a while ago (NOT Cousins) a used but good watch movement for spares etc. What arrived was a watch strap. Complained no reply as yet.
3.
The cat has just knocked over a cup of coffee in my main Mac keyboard. Hoping it will clean off with some warm water and dry out.
Bum, double bum in fact treble bum & blast
Oh gawd - coffee in the keyboard. I spilled a drop of coffee into the pad area on my Mac Book some months ago, and the mouse bit seized up - had to fit an external mouse until I could get it cleaned...
Best of luck!
Get yourself a large glass of Brandy (or tea) and relax. It's the weekend now.
That really sucks about your keyboard, they are not cheap (the apple ones).
I have cleaned as best I can with warm water and give it a quick blast with a hair dryer and put it in a airing cupboard and now hoping for a miracle.
A friend of mine found this method worked after dropping his iPhone in a pond. He was told not to turn it on until it was 100% dry & it worked.
Hoping for the same result.
The worst thing about a coffee spill is if you have sugar in it. One big sticky mess.
I use to see at least one laptop a week come in claiming they had done nothing to it. Open it up and lo the stickiness.
No sugar so perhaps !!!!!.
Anyway chilled out now had grandson around and one of his first words is GRANDDAD. Cheered me up big time.
Edited by clockboy
Hmm. Hope it'll be ok but best bet is to take pic of keyboard to remember where they go , take em all off and clean all with microfibre dipped in very hot water.
Microfibre will absorb all coffee and the hot water will evaporate quicker.
Edited by ro63rto
Ok thanks I did more or less what you suggested . It is in the airing cupboard now for the weekend I still have my macbook pro for any computing requirements.
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
