Rolex Cal 1560
Legarm
I think this https://www.cousinsuk.com/product/grease-moebius-8213-semiliquid-greaseis the grease you should be buying for the inside edge of the barrel.
Thanks Geo, I read an old Rolex service guide and it shows another grease of similar qualities. I have now gone for the 8201, " For springs and slow moving parts with large friction areas (barrels etc.) with molybdenum disulphide (a black crystalline sulfide, simular to graphite) usually applied cold."
I hope that is right............ seems to be the modern equivalent to MR.
9010 for balance endstones
9010/9020 or HP-500 for the train
D5 or HP-1300 for the high pressure train, motion work, barrel arbor etc.
8200 or 8201 for the mainspring (extremely fine film along it's length).
8213 or 8217 for the barrel walls to stop the bridle slipping too freely (small amount at three spots smeared around the wall, don't let it get pushed to the barrel floor when installing the spring), Automatic watches only.
9501 or MolyDX for high friction parts (cannon pinion, keyless work).
9415 Pallet stone oil
haha...solution in search of a problem?
Anyway I'm sure Rolex had a reason for this as they are not as 'gimmicky' as other manufacturers..maybe new hairspring material?
Apart from the oyster case, Rolex as a manufacturer is a bit boring in terms of innovating new tech..something like Mercedes in the 70-80s... their stuff works and works well but only because it's been highly refined..
Anil
All the oils arrived today, but have to put the Rolex on hold to make a watch for middle daughters birthday, so I have been told..... really told........... several times apparently ..... must have not heard the dear wife ..... :(
well that was a fun three weeks. Really ill, nearly put in hospital. Anyway feeling a lot better and hoping to stay out of hospital.
Started the re-assembly and have got the balance and guard installed, running nicely and good amplitude.
Will install the rotor and automatic works tomorrow, can only do a small amount at the moment.,
the bracelet, case and hands have been refurbed and looking good.
Will post pics of watch on completion.
Hi Legarm,
Glad you are back and fit again! Looking forward to the final outcome...and yes, stay out of hospitals they are not fun even with beautiful nurses. ( I don't see why nurses have to be beautiful since once you are in a hospital it doesn't do you any good!) :)
Cheers,
Bob
Bloomin eck! I'm glad to here you're up and running again...........along with the watch. I look forward to the next does of photos.
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
    • Yes Breguet overcoil, and A is OK, the damage is from B to the end. It should look lile this. The studd is fixed by the screw head into  the cut.
    • I opened up a 17 jeweled Swiss made movement only to find it has a pin pallet escapement. Not sure where the 17 jewels are but they ain’t on the pallet fork! Tips for lubrication?
    • Hi, This headstock is a little bit too modern for me to know my way round it. The pin that stops the collet spinning is sheared and needs replacing. Does anyone have advice on how to remove the spindle? I’m assuming that you remove the quick change assembly from shaft. Remove pulley. Unscrew front and back bearing plates on the headstock. Then press the spindle out applying pressure to the front (collet end). Has anyone done one of these? Any pictures or links to articles/literature gratefully appreciated. Thanks in advance. Warm Regards   Andy
