Swiss Emperor Watch - Any Good?
Some of the Roamers particulaly the ones with Brevette engraved on the caseback are front loaders if you hold the watch by the lugs and push on the crystal the movement caseback and crystal should come away leaving you holding the bezel , the crystal then lifts off and you can then remove the movement , as already mentioned some had split stems that would need splitting first but yours looks to be missing so no need to worry about that bit.
Need to see the caseback really to determine if it is this type but if it is it's easy enough
good luck
Andy
good luck
Andy
Hi Andy.
Yes, my one has Brevette ie Patent on the rear. Managed to remove crystal but stopped short of removing movement as I don't have a decent amount of time today. Maybe tomorrow.
Excellent! :-)
I've got a Ducati that just needs a battery!
I think yours only has two wheels though, doesn't it? [emoji1]
Took a look at mine under a loupe and realised why mine looked "fuzzy" compared to the one I just bought.
At first I thought because it was 10 years of constant use it had got scratched up. Nope, take a close look at this pic and think "ice crystals"
Took the movement out and cleaned the inside of the crystal. All gone now. Greased caseback and stem gasket.
Wonder what caused it? [emoji47]
Edited by ro63rto
Hi Roberto,
Looking in the crown post, is there a stem?
Anyway, this is what I woul do...
1st remove the chapter ring (the part with the minutes marked). Once this is removed, the movement should come out. If there is a stem then it may need to come out at an angle. I believe you will find it is a 2 piece stem with the crown part missing. Now that I think about it, even with a 2 piece stem you may find the movement will come out easier if you get the side opposite the crown out first.
Note! Save the crystal, these watches can be a pain to source crystals as the seal depends on the thickness of the crastal edges. If you look closely you'll see a step in the crystal edge (assuming its original).
Anil
Finally got the movement out.
The chapter ring comes off real easy.
Now for the bad news.
No crown OR stem! Looks like a spider has taken up residence in the resulting void [emoji35]
So the search is on for new stem and crown.
On a higher note, the movement is the more sought after (or so I have read) MST436 and looks to be in very good condition plus it has the original 7 jewel Rotor.
All in all a nice watch. Acrylic crystal is in Very good condition with only 2 light scratches. Easy enough to remove and I think the dial is in pretty good shape too.
Cousins list the male inner as well as 2 other stems didn't mention the female outer part though so whether the other 2 are one piece stems i don't know
Found a stem and no need to register AT ALL [emoji1] €10 plus €3 postage from Netherlands.
Now for a crown.
Roberto,
Beware ....instead of selling the crown you are more likely to buy a crownless Roamer hoping your crown will fit!
Been there.....
Anil
Stem arrived from the Netherlands.
I think they sent me the wrong one. Its not a two piece stem ie the crown screws to this one they sent instead of one that clips onto it. [emoji35]
That's a bummer, especially when it's an International purchase. :-(
Its a pain. Only £2 postage but the hassle. ... Thought I finally found it.
I found on Boley that they list the stem as Part 401.
This pic on oldswisswatches shows 401 and it looks similar except the resolution is bad. I'm confused. Wish there was someone with an exact watch to compare it with.
Edited by ro63rto
The company said they supplied the correct one ( even though I emailed them the model before ordering) but they will take it back and refund me.
Only thing is Royal Mail are theives and want around £5 to post it back. Not worth it.
Anyone need an MST430/436 threaded winding stem for a "Normal" watch case? [emoji16]
2765 is the correct part number. This is a split stem version and is the one required.
Called a "Stem for water resistant case"
Thanks Mark.
They have refunded me even though I haven't sent it back due to cost of postage.
Now to find someone that can sell me it using paypal as I no longer have credit cards.
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
