I've just refurbished a rusty 1164 movement following marks video of the Valjoux 7750. It running like a dream. I have a new seamaster 300m dial for it but now need some genuine omega hands.
Anybody know the ref numbers for silver skeleton hands to fit the 1164 please.
Also while I'm on the subject does anyone know a site that references omega cases and compatible movements that fit?
Thanks all !!
I usually use Cousins for my Omega parts - you can search by movement for hands and dials etc.. you search by case number for crowns, bezels etc.
This may change next year when the Swatch Group drops the hammer.
That's the double bind that Cousins gets you in. If you want a new case for a movement, then it's mandatory that you know the case number. But, if you don't know the number, how can you order a case - or hands - or anything else?
I would have thought that calibre was more important than case.
Willfly that's my problem.. I use cousins all the time but sometimes there referencing methods are floored. I have found some hands which look correct at cousins but there is no information of the pinion sizes,lengths or calibre. Product code: x28178, omega part number: 065PZ3988.
Found the case number after trawling through the bay and finding matching case and movements. It's 2298.80 but still no joy with cousins. The base calibre is Valjoux 7750 so no good trying that to get omega hands.
I always use the Omega Vintage Watch database. You can search using calibre or case number.
I punched in 1164 and it came up with a list
This is the 300
Seamaster300 Diver watch Reference 2598.80.00 International collection 1993 Movement Type: Automatic (mechanical) Caliber number: 1154/1164 Cal. 1154
Created in 1992
25 jewels
Cal. 1164
Created in 1995
25 jewels
Functions Date, Chronograph, Chronometer Case Stainless steel Case back Screw-in Dial Blue, “wave ” design, with super-luminous hour markers and skeleton hands Crystal Scratch-resistant and anti-reflective sapphire Bracelet Stainless steel Water resistance 300 meters
The reference is the case no. Heres the link    Hope its a help
With regards to Mark,s comment "Swatch Group drops the hammer". In this months (November)  bhi mag there is an article on the 33rd Hong kong watch & clock fair. In the article it states that Asian industry heads discussed issues related to the industry. The principal question at the seminar was the impact of the Swiss monopolistic policies of restricted parts supply. It reported there are" legislative moves afoot in France & Germany that may well have some impact on these restrictive practices"
Just wondering if anyone has any updates on this or is it just a false hope.
Edited by clockboy
Thanks Maurice.. I think there's some confusion between the model ref number and the case ref number. Model numbers appear to be xxxx.xx.xx and case numbers xxx.xxxx but I may be wrong.
Fantastic job, its a shame you may not be able to repeat this in a couple of years time if those idiots at Smersh Spectre err Swatch have their way, mind you, I expect there will be a good supply of pattern parts coming out of the Orient by then.
Speaking about the Orient, I wonder if the Japanese will take advantage of this market issue and try to supply parts too....Orient is a well known brand of mechanical/automatic in house movements, just like Seiko that might be interested!
I would guess that China will lead the charge.
Thanks for the kind words.
I chose this movement carefully for my first chronograph restoration.
As its base calibre is a valjoux 7750 I knew I could get parts cheaply and easily. I cant see omega clamping down on this one. Also hopefully having a good resale value as its a prestigious brand. You don't see many 1164 movements for sale.
Apologies if this is a rude question, but I am very curious...
What did this transformation cost, from the rusted Omega to the parts? i have been amazed at some of the watch transformations I've seen on this website and Mark's videos, but I have no idea what things cost.
Movement cost me £100 on the bay. Parts around £80 mainly chronograph parts. Then the dial was £60 and hands £40. So £280 in total. A nice case and bracelet would value it to between £1000-1300 I guess.
  • 2 years later...
Hi chrisbuxton27,
Thought this forum is from 3 years ago, i am having an issue with my 1164 movement, it stopped working, i would like to know how did you refurbish the movement, it will be a great help if you can share information/document/videos. this is my first time working on a automatic watch, i know it takes a lot of patience and skill, please help me .Thanks in Advance
Raj
  • Similar Content
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
    • How do I remove the hairspring from an ETA? 2846. Balance  staff pivot is broken and I need to transfer the spring over to a new wheel. But the spring stud is not removable. It seems it almost looks like a snap ring at the top of the balance cock or am I missing something?
