Watch crystal cracks
Norken
Hi!
I’m new to amateur watch repair and refurbish and am very glad to have found this forum!
Recently I have had issues with watch crystals cracking when I polish them. I remove the crystal from the case and start polishing with wet sanding sheet (grit 1000 & grit 3000) and water (with a dash of washing liquid). The polish have resulted in a cracked glass in my two last attempts. I guess some kind of tension have been built up but how? And more important, how can I avoid it?
Thanks a lot!
Is it glass or plastic? From your picture it looks very scratched to be glass. Over time plastic becomes brittle and stars to degrade. The way forward then is a new crystal. At not very much money it can enhance the look of an otherwise dull and uninteresting watch. If its glass I have had some success with a small jewelery buffing wheel and a small amount of 'Dialux buffing paste. Place the glass on a soft surface and gently buff the whole surface. You can do it by hand but its a lot more work. Don't introduce too much pressure though because the heat generated will crack the glass. My own personal opinion for what its worth is 'New every time'
It’s plastic, the scratches comes from that I had started the process to polish it. Agree that sometimes a new crystal is to prefer but quite often one can polish up the old one. But what could be the reason for them to crack like this did? Thanks!
As mentioned previously the plastic has probably degraded. It could have been cracked before you removed it from the watch. Sometimes cracks in acrylic are difficult to detect especially if viewed straight down. Sometimes only visible when looking at the rim.
Probably it was quite happy whilst in the watch but could not withstand the stress of being pushed out and polished. The rim is the weakest point.
Ahh i see. Could very well be the case then. You learn something new every day :) will look more carefully in the future. Thanks!
I don't usually remove them. I think compressing old brittle plastic is bad mojo. I polish them in place, mother's mag and aluminum polish. put some on a paper towel , laid down on a flat surface. press down with light pressure  and do figure eights.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
