Best method to flatten and "coned" hairspring
Maybe you could try a rubber ball or a suction grip opener. https://www.cousinsuk.com/product/suction-grip-dies-with-holder-cousins As a last resort, you could try the glued on nut trick. -
I know clockboy has the cleaning machine which is the one from India and he has said it is a fine machine giving good results. As you have good contacts and are willing to do the wiring it is up to you. I don't like to boast but all the photos of the machines I have had them or similar. The red one I had for cleaning small clock movements such as travel alarm clocks. I don't think there is much more I can say in giving advice. Good luck in what you choose and do let us know and if you obtain one post photos of it.
By rjenkinsgb · Posted
OK, the bayonet style fitting makes sense for alignment. Can you post photos with the bezel off? -
Thanks for the great advice....if you would like to donate a lathe to me so I could learn that would be fantastic 👍
