So I failed miserably at drilling out the old pivot. It was way too hard the center before drilling it out. Any suggestions?99b895c9be0e6c4fe27155e87dbd6019.jpg
  On 12/9/2018 at 11:08 PM, clockboy said:
I would think you will have to anneal the old pivot.Although when searching on the net know-one seems to do this.
A book I have suggests that you need to anneal it as well but recommends not to if it can be avoided. As well, the part is so small and the pivot is in the pinion side so very hard to heat. And the new balance was working so well.
  On 12/10/2018 at 8:06 AM, oldhippy said:
What type of drill did you use?
It was a micro drill used for PCBs I think. I could not find a small enough standard roof topped pivot drill.
Sent from my GT-N5110 using Tapatalk
a little off topic but here goes I went to machinist school, and I used to think that you blasted a drill bit through steel with high speed, in actuality old drill bits were hand cranked so HIGH SPEED could mean anything above that, now I use the slowest rate I can to drill, 50to 100 rpm,  and I use a mixture of olive oil and dawn dish detergent in a little water, shake it up  each time!!  it work especially well on stainless steel, rate of feed is force, to the object, so if you feed hard or press hard you are heating the bit NOT allowing it to cut but wearing away the sharpened bit, I cant take a COBALT it and put it to stainless with no lube press to hard and it will sit there and spin,  ADD the goo, spin slowly with lighter pressure and you will see curls of stainless coming off the bit.. cobalt its are much larger here in the USA, not for watchmaking, I have only found just steel bits, but the principal applies, I did 3 pivots on and old LaPhare  Moonphase pocket watch  I used 2 bits , the first one I have an involuntary jerk from time to time and that occurred breaking the first one, chucked up another one and hand pushed it against the staff so I could Feel the pressure , and it went in, and YES you may have to anneal if you know all this I apologize not trying to tell you what to do, just my experience
Really appreciate the help. Not sure how to anneal when the pivot is so close to the wheel and leaf gear, pinion.
I can recommend carbide drills from eternal tools. See my second to last video on YT, repairing a broken pivot. and you will see They cut through like butter.
Sent from my SM-G950F using Tapatalk
This thread is fast becoming a favourite! Hopefully next you’ll break a wheel and have to re-machine one from scratch, or find a broken jewel as could do with learning that too! [emoji897] [emoji3047]
Thanks Mark. Btw I bought your training session on watch repair and am going thru all the training now. I am picking up tips on diagnostics hear and there, appreciated. I will check out the carbide bits.
I made a jewel replacement video on YouTube a while back. jdrichard01
Mark, these are on eBay. Have you used these in the past.5dffe6989d2ef1d5408d52faa9781398.jpg
Expand
I have purchased some from eBay and I found them crap. I then purchased some from Eternal tools and the difference was remarkable. I also have purchased some larger drill bits from Axminster tools which were also very good. As the old saying goes "you gets what you pay for".
Axminster is where I went to school and in the town I served my apprenticeship. I can remember when Axminster Power Tools first started. Now they ship all over the world. They supply the UK army with engineering equipment such as lathes and power tools. The chap that started it all up is now in a home in Seaton poor old boy, such a nice person too.
I think you are right and I may need to pay the high price for a single drill bit. The price of the drill bit is almost the same price of a new part.
    • Ah yes - That second ebay one looks identical. It mentions Revue - The Revue 31 Hunter is clearly from the same factory. This one is a blinged up version.
    • There is one listing on eBay: https://www.ebay.ca/itm/126044951473 And here is one SOLD listing: https://www.sellingantiques.co.uk/345530/1920s-federal-full-hunter-pocket-watch Revue?
    • Out of curiosity which oil did you use? Oh and yes oil does have a dampening effect. It's actually quite interesting if you take like your 6497 clone clean it lubricate all the key lists mainspring etc. do not lubricate the watch. But on the timing machine see how it looks start oiling the watch see what happens you probably see a loss of amplitude at least until you get to the escapement and then you'll see a spectacular improvement so oil doesn't always have a spectacular increase in amplitude but you definitely have to have it One of the ways I explain learning watch repair would be similar to learning to be a doctor. Have you ever noticed how doctors say they're practicing or they're in a practice why are they still practicing shouldn't they get in the game? That's because they are still practicing their getting better the same as were getting better each of our watches is like a patient guess they're similar but there are also different but all different and we are practicing every single day but typically in watch repair people watch a video they practice on one watch taken apart a couple of times just like you did then they want to get into the game they want to work on a live watch to learn experience. Problem is experiences learned over time a very long time in the case of watch repair and as you can see working on a vintage watch requires a heckuva lot of knowledge and egg a lot of remembering things like for instance that 5° angle thing that you mentioned up above wider to go look at the first page of this discussion somebody already showed you that. The problem was too much knowledge being gained too fast and you didn't absorb it because you can't. Knowledge of watch repair is learned over time. Knowledge of vintage watch repair is learned over a considerable quantity of time because there's so much stuff going on so many things to deal with oh and we are learning watch repair like at least in the old days when their learning to be a surgeon they got the work on dead bodies I believe now they get to work with computer simulation. They do not jump in the field and start cutting apart people like we do in watch repair where your practicing on. Outstanding idea as you're here to learn. To be quite honest I think practicing on 3 to 4 unimportant pocket watches is outstanding but realistically you're going to need more experience before you really start restoration work and you're going to need more equipment like a watchmaker's lathe would be nice. Then ideally try to find some pocket watches that aren't totally destroyed. Because ideally with learning you actually want to learn and grasp what you did or did not do to end up where you are as opposed to where we are now Now that you have greater knowledge of pocket watch repair man make a suggestion is going to require considerable patience though.  Go back to page 1 of this discussion and read through the discussion do not act upon anything you see just read the whole discussion again.
    • These look to be the same and similar movement on ebay, branded "Watches Ltd" - not really much help unfortunately. The only possible clue is another from that brand with a (different) Cyma movement? https://www.ebay.co.uk/itm/165326228991 https://www.ebay.co.uk/itm/192889602809
    • Yes the problem of finding the software this is because he does not have a website he has the files in the file directory someplace so finding it becomes extremely challenging if not impossible. He should be here but is not? Try sending a private message to Frank @praezis It's his software he should bill a tell you worries currently hiding it.
