Hello,
I’ve been ‘lurking’ on here for some time and seen a great advice and hoping now someone can offer some for me. I don’t think I’ve missed a similar posting.
I am trying to restore my father’s watch in time for Christmas. It got wet in a torrential downpour some 15 years ago, it stopped running and was left in a drawer. It has an ETA 2452 movement.
It was quite a mess when he gave it to me “to see what I could do with it”. Very stale oil mixed with water didn’t smell great and obviously some resulting internal corrosion too.
I have cleaned the parts and replaced those that looked damaged. I have installed a brand new complete balance and other parts replaced from donor pieces.
I completely reassembled the watch (minus hands, dial and case) but found it would only run for very short periods. Dial up or Dial down appears to make little difference.
I dissassembled and re-assembled up to a complete train of wheels and escapement with power and setting.
I have found the watch runs but stops at around a full minute, typically one minute but can run for two or three but always stopping around the full minute mark, at least within a margin of error for me hitting the stop on my timer. The escape wheel comes to a gradual halt, the pallet moves weakly back and forth without the escape turning and then the balance gradually comes to a stop.
A light touch on the escape pivot or train wheels/pivots is enough to have the watch continue running again… for a minute.
I have very closely inspected the third wheel, fourth wheel and escape wheel in particular and can see no obvious sign of damage. Nor do the jewels appear damaged. I don’t posses a truing caliper so its possible there is some small misalignment in the pivots I guess creating some friction? Before I try and source replacement wheels I thought I would ask if anyone here had experienced a similar problem or could offer any advice? All gratefully received.
Thank you.
Thank you so much for the feedback.
I've inspected the 4th wheel especially again and can't see anything amiss.
I'm going to clean the wheels again and retry.
Hi martint,  when stopped, mark a dot( majic marker) on the escapement wheel ,say the tooth engaged with a pallet jewel, get the movement to run and see if stops at the point, repeat to increase validity of the collected data. Do the same(Dot hot spot) with the minute wheel. The collected data can by itself point out the fault, report if you will your observation on the forum.Brings in more advice.
In case you disassemble the movement mark the corresponding tooth on gear/ pinion on arbors, escape and minute as well, as a simple operation with razor blade may be all required.
Regards joe
While at it, if you loosen the cabs jewels on escape and fourth wheel and drop a droplet of lighter fluid on escape and fourth cabs and why not on fork arbor and balance jewels.
If no noticable difference remove balance with cock and the fork, manually wind ( normal wind speed) to run the oiled train for a minute or more.
Oil the inside of center tube and once you gain access clean tubes inside by making  use of the seconds wheels shaft as a tool.
Once these are checked and fault not found, I will send you pix on safe brush cleaning of a wheel before you resort to buying new one.
Regatds joe
Thanks Joe, some useful advice there. I will reassemble and try marking the sticking point to see if the narrows the issue.
The train appeared to run quite freely when I've previously assembled. I've always used 9010 on the pivots and 9415 fork.
Prior to this round of cleaning I took a photo of the main suspect. This was one of the original pieces.
I'll report back when reassambled.
Thanks again.
Hello All,
I thought I would update as I think I found my problem.
I looked closely again after cleaning and a little embarrased to report that for all of my focus on teeth I missed a slight kink in the sweep seconds wheel itself. I straightened by hand as best I can (probably enough to be in a level of tolerance) and have reassembled the train and things seem to be running continuously now.
Will work on completing the reassembly and getting it on the timer. I feel better about being complete for Christmas!
Thank you all for your feedback. I appreciate it. A lesson learned I think.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
