After a years hiatus from my watch project(renovated house after tenants from hell) I find I have to put in my third balance staff. This is on my 1892 model Waltham pocket watch by the way...
The second balance staff went well,except I kept dropping it on the floor and bent the pivot. My attempts to straighten were to no avail. So I have sourced another staff. The problem with this staff is the pivots are 13 size instead of the 11 they should be. I have a Seitz jeweling tool as well as a nice Jacot tool. So my question is, leave the pivots alone and put in new balance jewels or turn down the pivots with the Jacot tool. What is the accepted practice? My first attempts with the Jacot tool brought mixed results. I found my new pivot file/burnisher very quickly took the bent pivot from 11 size to a 9 very quickly.
Waiting for my bench practices book to arrive...
Ron
Ron it is what you are are confident with.Changing the jewels is relatively easy and reversible if it does not work. However if it was me I would adjust the staff using a jacot tool or the easiest option is to purchase then correct staff and keep or sell on the wrong staff.
What fun.:)
I guess if you put these in order of risk from least to most then it's
1 - Find the correct staff.
2 - Replace the jewels.
3 - Modify the staff
But then again, as a learner, I like to challenge myself to take the more risky option in order to gain experience. But of course that can be an expensive choice.
Hi, I would 1,3,2 you should keep it as standard as possible
Regards Kaz
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
